What year and # Prius do I get?
Discussion in 'Gen 3 Prius Main Forum' started by Koko, Sep 3, 2012.
  1. Koko
    Koko Junior Member
    35
    I'm shopping around for a car and had my heart set on a Prius. Much of my driving is made up of 1+ hour trips, and @ $4/gal, fuel efficiency is high on my 'must have' list. I'm just so overwhelmed by all the Prius choices and in reading this and other sites, am starting to get cold feet about making such an investment. Our funds are far from unlimited and here in the New England, Prius prices are several $1000s more than out west. I just want to make sure I make the right choice.
    I've purchased several cars throughout the years, including 2 Toyotas, one of which we still use at 200K+.
    I originally started our Prius search w certified preowned vehicles (Gen 2 or 3) yet after speaking w a local who owns 2 Prii (09 & 12) & loves them but refuses to drive in snow (because of their 'poor handling'), I read the thread about snow and am now leaning towards a Gen 3 (w snow tires). I road tested a 2010 but upon further research, have decided to forgo that year (the brake/accelerator issue concerned us as it reminded us of our Honda Odyssey).
    I also have a weaker lower back and often get leg cramps from driving (I'm 5'5"). I've seen extensive posts about a poorly designed driver's seat and owners who are in severe pain from driving the Prius. Yet the idea of paying approx $28500+ for 2012 w power seats is far beyond our budget. I'm aware that the 2011 4 had the manual seats and power lumbar. (Did it provide good support)? Is the seat height adjuster any good?
    It also seems that there is an 'art' to driving a Prius. I like the thread that suggests imagining an egg beneath the pedal. I wish I knew it to tell the Toyota salesman who took me out for the test ride and told me to "really push down on the accelerator for speed" when I was driving briefly on the highway!
    Feedback/suggestions/guidance are appreciated.
    Thank you ~
    Koko
    Btw, I indicated '2011/2' in my profile only because there wasn't a 'future Prius owner' option ~
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    A lot of those complaining about the seating are over 6 foot. Snow tires are your friend in winter. 2010 models with issues have them resolved by recalls. "Rent one for a week" is really good advice.
    Koko and cwerdna like this.
  3. Koko
    Koko Junior Member
    35
    Appreciate the >6' tall info. Renting one is great advice :)
    Thanks, Jimbo!
    52,861
    my wife has a bad back and loves the seats in the hycam. 28,000 will get you the base model and 45-50 mpg's. very quiet and comfortable.
  5. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    The "egg between the foot and the pedal" is not the best way to high MPG with a Prius. I suggest you read the many treads about driving technique.
    There are always a few people who find almost any car's seats uncomfortable. I second the suggestion of renting a Gen III for an extended test drive.
    There is nothing wrong with the brakes on the 2010. They were reprogrammed/recalled to avoid the "seat of pants" feeling of acceleration that you get with the Prius. You just need to retrain yourself to mash the brakes harder if needed.
    I have both a 2008 Gen II and a 2010 Gen III and think the the 2010 is the better car. Since the HV battery deteriorates more with age than mileage, I think the Gen III is a better buy as a used car.
    ralleia likes this.
  6. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    I don't own a Gen 3, but agree that it is overall a superior car compared to Gen 2. See posts by me, Tideland, evpv at Prius versions | PriusChat re: Gen 2 vs. 3 changes. There were a LOT.
    Yes, if one drives in the snow, good snow tires should solve any snow driving problems other than ground clearance.
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    And ground clearance can be helped by choosing a slightly larger tire. :)
  8. Koko
    Koko Junior Member
    35
    Thank you all so much for your input. You're helping tremendously :)
    Will read up on the specific threads you've indicated.
    Being that they're the same gen, were there significant differences between the 2010-2011-2012 cars or were there just minor tweaks?
  9. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Straight from the horse's mouth re: '10 vs. '11 at MY11 Prius | PriusChat
    '12 was a mid-cycle refresh. Some changes outlined at Exclusive: 2012 MY Prius - Changes and Additions | PriusChat. It is incorrect about the Model Two including backup camera. Unclear if that was an error or a last minute change. The most visible differences are the taillight and wheel changes.
    Toyota Vehicles : Toyota Announces Prices for 2010 Prius / Toyota has 2010 equipment levels and old, outdated pricing. '11 is unchanged except they moved away from Roman numerals (see earlier post). The press release omits USB though, which came w/later builds of 2010 Model III's w/nav (Three in '11+ parlance).
  10. Filmmaker1225
    Filmmaker1225 Junior Member
    33
    Santa Monica, CA
    I'm 6'4" and I find the driver's seat quite comfortable in my 2010 Four. It isn't power, but completely adjustable; up, down, back forth, recline, and lumbar support, which is stronger than the same device in my 2004 Nissan Maxima.
  11. Rosie2124
    Rosie2124 New Member
    16
    We just went through this ourselves and finallly ended up purchasing a 2012 Three. I've known since probably February or March that I definitely wanted a 3rd generation Prius and like others suggested, I did rent one for a day just to be sure. That actually completely convinced my husband. He did not expect to like it as much as he did. I originally wanted a used Prius with low mileage, but in the end the prices were typically not low enough to really make a difference and since I wanted a specific color it was even harder to find. Given that we were going to be paying over $20K no matter what, I wanted the car in very good shape and that was also difficult to find. I'm in New England as well and it is definitely difficult to see all the great deals people on the west coast get. Anyway, like you, as much as I wanted the Four with the better seats, I couldn't justify spending the money. We went with the 3 because of the backup camera, nav and sks on three doors. I felt if the backup camera is potentially going to be required on all cars at some point, I might as well get it and I'm not one to deal with adding all sorts of after market items. We did add the leather and heated seats though. I went back and forth between the 2 and 3 for a while and decided that since we keep our cars for so long, I might as well get the one that I really want since the difference wasn't that great in the long run. If we hadn't been without a second car for so long and I didn't want a specific color, I would have definitely waited for the right used one, but at this point we just wanted to be done.
  12. Koko
    Koko Junior Member
    35
    Thanks again, everyone, for your input! Surprised myself by ending up w a new 2012 Prius v ~
    ralleia and spiderman like this.
  13. ralleia
    ralleia Active Member
    386
    137
    Omaha, Nebraska, United States
    Congrats!
    When do we get to see the baby pictures?
  14. Koko
    Koko Junior Member
    35
    Thanks, and lol - I'll post one as my avatar ;)
    ralleia likes this.
