What Year Range For 4th Gen Engine Swap?
Discussion in 'Gen 3 Prius Technical Discussion' started by Tusker, Apr 23, 2024.
  1. Tusker
    Tusker New Member
    22
    Missouri
    I just bought a 2011 Prius with a hole in the block and am looking for an engine to replace it with. I'm highly considering a 4th gen swap, but am unsure what year range I need to look for. From my understanding, 4th gen refers to 2016-2021 Prii, but information I've seen on here suggests that I should look for a 2016-2017 engine for my 3rd gen.
    Can someone please clarify for me what year engine I should be looking for?
    Thanks in advance.
  2. PriusCamper
    PriusCamper Senior Member
    13,459
    5,430
    Pacific Northwest, USA
    Make friends with this dude who's near you: https://www.instagram.com/skimmilkhybrid/
    He's realizing that JDM used engines have quality control issues. So buy one from a local wrecker or hire him to build you one of his custom engines which is a Gen3 rebuild with Gen 4 cams, pistons and connecting rods...
    #2 PriusCamper, Apr 24, 2024
  3. Tombukt2
    Tombukt2 Senior Member
    13,858
    2,516
    Durham NC
    Reevaluate your situation very carefully again If you're a computer person a spreadsheet guy and number crunch or and all that well you may find out that this is a game you do not want to play look at your car carefully look at other cars online similar to yours used similar to yours and look carefully if there's some in your area take a look like I say if you don't have some money that you can afford to lose this may not be a thing for you in any sort of way I'm looking at the location and all of that when I say this I mean if this is something that you really want to do because you do then not much anybody's going to say can help I've only been bitten by this once and once it will only be I've been with Toyota for 47 years of driving You only get one chance to burn me only one Chevrolet or General motors has never been able to get me because I've never driven their mess The generation 3 was my fault My mistake Toyota has never done me any wrong and I didn't do my due diligence I allowed girl power it's 5 minutes of fame and that's what it brought to me. My girlfriend really wanted this persona I told her it looked like something that was made to be thrown out yesterday but I like it it's so cute and it's black cherry colored and well the rest is history and in the trash it is not worth my personal time and personally I don't see this is a viable car this is like a throwaway thing to me That's a personal issue Just be careful hopefully you have a bicycle a scooter another car etc and this is just something to play with this is serious dependable transportation that you need to survive well you're barking up the wrong tree almost for sure.
  4. Tusker
    Tusker New Member
    22
    Missouri
    Thanks for the contact. I'll look him up and see what advice he might have. I'm a DIY guy, so unless he's insanely cheap, I won't have anyone else do the work for me.
    I've actually used JDM before, with good success. But JDM or not, it would still be helpful to know what years of Gen 4 are appropriate for a swap into a Gen 3.
    Thanks for the reply, but I'm not sure what you're trying to say here. Are you suggesting I stay away from Gen 3? Are you warning me against JDM? Are you telling me I should reconsider trying to get a $500 Prius on the road after an engine failure?
    #4 Tusker, Apr 24, 2024
  5. Tombukt2
    13,858
    2,516
    Durham NC
    If you've only got $500 in it you can afford to spend $2,500 and piss around easily You won't lose anything If the cars are reasonable shape you could make out pretty well can't see it from here but a lot of these things have lots of problems. JDM is not a problem I've been buying JDM since ATK in the '80s yeah I know. So I've been putting in engines that didn't come in American Toyotas for a long time and had a great time messing with all that stuff generation 3 for us was unhappy experience and that was that I hope it's much better for you.
  6. Tusker
    Tusker New Member
    22
    Missouri
    Does anyone have information on the year range of 4th gen engines that will fit a 3rd gen?
  7. Tombukt2
    13,858
    2,516
    Durham NC
    They will all bolt up It's a 2Z FXE regardless there's a few hose routing changes things like that but none of the generation 4s are the same as the threes the EGR passageways have changed gotten smaller I think etc and so on but they'll all bolt up to the transmission and drop in the car no question about it so that's not going to really affect the year model so much some of the other engines had coolant take offs that aren't used or not needed in the generation 3 You can read about how some people have gotten around this now others have suggested to get around it and so on pick your poison methodology and roll with it see what happens.
  8. Brian1954
    Brian1954 Senior Member
    2,679
    1,071
    South Central PA, USA
    Model year 2016-2022 Gen 4 engine can be swapped into a Gen 3.
  9. Tusker
    Tusker New Member
    22
    Missouri
    Perfect. That's what I was looking for. Thanks, guys!
  10. Mendel Leisk
    42,343
    Consider getting a third Gen short block. Brand new from Toyota they’re under two grand USD. They will have the updated pistons and rings, sim to Gen 4. And be 100% compatible, whereas with a Gen 4 engine you will be doing a lot of “adjustments”.
    Gen 4 salvage engines have pros and cons. There’s been subsequent overheat reports, for one.
    #10 Mendel Leisk, Apr 27, 2024
  11. Mr Cleeb
    Mr Cleeb Junior Member
    Nevada
    2017 Prius v wagon
    I may be a little moronic, but Googled this a handful of times ... is there a specific website / link you have, and if so ... willing to share, please? Thank you in advance!
  12. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    He's talking about purchasing an OEM short block, which is just part of the engine. You can search part number 11400-37140 to see what that entails. For more info see the Youtube video by Car Care Nut about a ct200h, where he does exactly this.
    Brian1954 and Mr Cleeb like this.
  13. Tombukt2
    13,858
    2,516
    Durham NC
    What's this open deck design when you buy the proverbial short block you're you're just getting the middle section I don't think that includes the girdle the oil pan and so on so you're getting the reciprocating mass in its housing and then you're going to put all your external metals and whatnot on to this assembly so your other stuff can't be damaged like something went through the side of the girdle or the middle section or whatever that's called that's how these open deck things are built so you have to have all those pieces or several junk engines to take all those those two pieces from something I don't think I would want to be buying all of this new from Toyota but then again some people
  14. Mendel Leisk
    42,343
    This is regular gen 3 short block, but I believe Prius v is identical. Check with your VIN, and you could also plug that part no into search field of Toyota USA’s part site. Also can confirm and cost confirm through local dealership parts department:
    https://www.amayama.com/en/genuine-catalogs/epc/toyota-usa/prius/ZVW30L/13501/engine/1102
    the short block is the layer between upper oil pan and head gasket. Upper oil pan is a not insignificant, aluminum casting, with the stamped-steel lower oil pan on its underside.
    last link in my signature is the full engine section from gen 3 Repair Manual. (On a phone turn it landscape to see signatures)
    Mr Cleeb likes this.
  15. rjparker
    rjparker Tu Humilde Sirviente
    11,097
    6,963
    Texas Hill Country
    Tom is absolutely saying stay away from a gen3.
    There is no definitive guide or website on how to convert to a gen4. It does require custom mods and use of gen3 intake, exhaust, egr and obviously gen3 wiring harnesses and ecus.
    The gen4 cooling system is different as well including a different water pump, a water pump to egr bypass and a coolant selector valve. The valve can't be controlled by a gen3 so it is left off as is the bypass. Some end up with engine overheat indications from the temperature sensor downstream of the exhaust heat recirculation system. Others claim no issues but variations of the custom mods are likely.
    Most would go JDM for a low cost fix but a rebuilt gen3 engine is better and more reliable if you want to keep the car.
  16. Mr Cleeb
    Nevada
    2017 Prius v wagon
    Thank you, Eddie ... I recently subscribed to that YouTube channel ... genuinely good stuff there
