What you don't like about your Prius?
Discussion in 'Gen 3 Prius Main Forum' started by txl146, Aug 22, 2011.
  1. PearlJammer
    PearlJammer Member
    112
    23
    Georgia
    2018 Prius
    :pound:
  2. Dragonrider
    Dragonrider New Member
    17
    Tualatin, OR
    After a year of ownership - having other drivers treat the car like last generations VW - regardless of the speed driven, and the world treating you like you are a "greenie"….
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    The stigma.
  4. totfit
    totfit Junior Member
    US
    Personally, I haven't really noticed any sluggishness in the steering nor do I have issue with the rear window. I kind of like it as I feel a bit more "private" and it makes it easier to ignore folks behind me that are a bit anxious. One thing I have issue with is the rear view mirror. I have the garage door opener and auto dim mirror and it is difficult to keep adjusted and continues to need adjusting to keep its proper position. The heating system is a bit "different" from my experience and took some getting used to also. Other than those minor issues I love it.
  5. pictone
    pictone Junior Member
    Atlanta
    and another thing . . .
    Does anyone know how to get the climate control to just vent outside air without either heat or AC? If I do not press the Auto button or the AC button and turn the fan on will that accomplish this? If it is 50 degrees outside, I want fresh air, not necessarily heated air.
    My last car was a 2007 Hyundai Sonata. I think that I set it on an automatic temperature when I first bought it and didnt touch it again for four years. I find the Prius climate control very frustrating, needing constant adjustment.
  6. El Dobro
    El Dobro A Member
    7,106
    3,282
    That's what I've been doing, along with adjusting the temp to around what it is outside.
  7. itengineer
    itengineer Member
    86
    25
    Minneapolis
    Set the temp. Unselect AUTO. Unselect AC. Toggle recirculating to fresh air.
    However, you probably do not want outside air unless you're in the country. Otherwise you are breathing nasty exhaust of the car ahead. (CO2, CO, NO, etc) The particulates are blocked by the filter but CO2, CO etc come right in. Not to mention many older cars do not have their emissions controlled and likely are producing enormous quantities of CO.
    Which is why NASCAR has a air cleaner on their cars.
    It's best to drive in air re-circulation mode.
  8. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    This tends to increase the humidity in the car and fog up the windows, especially during colder weather. I've found my car tends to fog up as the temps get colder even when running in auto, AC on, and ECO. I'm experimenting with running in normal (non-ECO) mode and other adjustments rather than defog all the time.
  9. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Have a bunch of copies of a typical gas receipt showing about 50 MPG at the pump (your miles/refill = MPG). Hand one out to each naysayer and tell them to compare your numbers to their next refill.
  10. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Air recirculation mode? Not for full time operation. Any time it's raining and I see a car with the windows fogged, I want to tell them to switch off recirc.
    But being able to vent fresh air into the cabin without heating or cooling it—or having the A/C compressor come on—is a very nice option, including when the air is being directed to the defroster vents. Lots of new cars automatically start the compressor when some percentage of air is directed to the defroster vents. I know what they're trying to do, dehumidify the air, but being able to run without the compressor on saves gas.
  11. Tideland Prius
    16,684
    For full manual operation, you need to touch the MODE and FAN buttons.
    So, set the temp, turn off A/C (although in AUTO mode, A/C on doesn't necessarily mean it's running but that's another matter), set the desired fan speed and set the mode to the HEAD and set to FRESH AIR.
    Now you're in full control.
  12. pictone
    Atlanta
    Tideland,
    When you say "set the temperature", Do you mean to set it to equal the outside temp? If I leave it at say 72 degrees will the heat come on even if Auto is off?
  13. Canard
    Canard Member
    223
    Ontario, Canada
    Yeah I've wondered the same thing too, the manual isn't exactly clear. I just want everything "off" (no heat/no cooling) and the fan to blow, LOL
    I don't like that if you've got cruise on (ie, 80 km/h limit road) and come up to a stoplight that turns from green to amber, touching the brakes lightly to enter regen doesn't work... if you deactivate cruise by applying the brakes (even gently), it goes instantly to friction and you can't get regen back until you're at a full stop. You have to manually deactivate cruise (pull the stalk) and then apply the brakes.
    -Iain
  14. Canard
    Canard Member
    223
    Ontario, Canada
    I prefer the plastic covers/15's vs. the ugly touring rims. I think they look awful!
    -Iain
  15. El Dobro
    El Dobro A Member
    7,106
    3,282
    Like I said earlier, adjust the temp to as close to the outside air as possible. If you don't, the ICE will come on to get the interior temp up to what you set. When you turn the fan on, the system is on in manual mode.
  16. Much More Better
    Much More Better Active Member
    655
    163
    I am floored that people don't like the 17" rims. The most important thing is looks. I wouldn't have even bought a Prius without them. Secondly, the handling is a step up from other cars. I had an Accord before and this feels more surefooted. I also rented a Civic and a Ford Edge recently and felt that they were floaty. My V ain't a sports sedan but I like the balance between having comfort and enough road feel. Maybe one day I should test drive the 15" version and see if it's any different.
    My main beef: No USB in the Touring trim. Grrrrrrrrr.
  17. Mendel Leisk
    42,383
    ^ We went with the Canadian model that has the 17" rims, but it was not so much the low profile 17"'s as the plastic wheel covers on the 15" that swayed us.
    I've just put on 195/65R15 Winter tires (on steel Corolla rims), and there's no noticeable difference in feel. Well, maybe just that the suspension feels a bit more flexible.
  18. fulltank
    fulltank New Member
    230
    38
    Arkansas
    Am I doing something wrong??? My presets on the radio never seem to stay? Especially with XM Radio? I find a station, hold the preset button til it beeps, then for some reason after a few days of toggling back and forth from XM and FM it seems to disappear?
  19. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    Regen will work if you press the brakes lightly independent on whether you have the cruise control or not - regen or not depends on how you hard you brake, not on how you were driving up to that point.
    Where did you read that with CC on, regen does not work and that you have to come to a full stop before regen will work again? and BTW, braking is equivalent to pulling the stalk. Or have you read somewhere that there is a difference between deactivating CC (not turning it off, I mean) with the stalk and by depressing the brake?
  20. Tideland Prius
    16,684
    It depends on the outside air temperature. That's the beauty of the automatic climate control. I could set it at 22 or 23°C all year and leave it at that if I wanted it to and it'll cool itself in the summer and heat the cabin in the winter.
    If you really wanted to make sure it's only cool/cold air, set it to LO or just about it (65°F I think??) and it'll blow cool air. Just treat the TEMP switch like the cold/warm/hot dial of non-climate control cars.
    LO is cold and HI is hot.
    Set it to LO or 18.0°C, set the fan speed to low and the MODE to the face. There's your "VENT" setting.
    Are you sure? Even if you release the pedal and reapply? Did you confirm that with a scangauge? It seems odd because the Prius is programmed to take advantage of regenerative braking (less so now thanks to the stupid brake pedal thingamabob that forced Toyota to bring in the friction pads sooner.)
