What you don't like about your Prius?
Discussion in 'Gen 3 Prius Main Forum' started by txl146, Aug 22, 2011.
  1. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    I don't like the ICE turn on Algorithm. I can have the engine up to temp., the climate control system off , the battery fully charged and be dong a nice long slow 30 mph coast in neutral for miles , and then have then engine kick on for no good reason and start putting out 4 hp and its going nowhere??? Why ? The car is in neutral, no power being used, battery is not getting charged . Also had this happen when drawing power slightly , very low down on the HSI electric range as well. Seem to be no good reason to waste gas that provides nothing to the car.
  2. Tideland Prius
    16,678
    IF you're in neutral, the engine wouldn't kick in until you go into D IIRC.
  3. El Dobro
    El Dobro A Member
    7,102
    3,282
    It would be nice if the mirror adjustment switch was illuminated at night.
  4. txl146
    txl146 Member
    301
    NY
    no place to store coins...
  5. seether166
    seether166 New Member
    32
    Syracuse, NY (USA)
    Ditto for gauges' brightness dial.
  6. El Dobro
    El Dobro A Member
    7,102
    3,282
    Everytime I'm digging around to tilt the mirror becausee some a$$ is behind me with his highbeams on, I keep hitting the dimmer.
  7. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    Did you know that in some states it is illegal to coast a motor vehicle in "neutral"?
  8. El Dobro
    El Dobro A Member
    7,102
    3,282
    Theparking brake warning light should also be a bit more noticeable.
  9. Tideland Prius
    16,678
    I believe a chime will sound if you do drive around with the parking brake on. (it's the same as the key-in or door ajar chime)
  10. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Supposedly, it's to heat up the catalyst to keep down emissions. I wonder if it has any relationship to the way a particular emission test is designed and needing to pass/do well on it. Agreed that it is annoying. In some (many?) cases, on my 2nd gen, at least the HV battery is being charged a bit during this useless run.
    As a side note, it seems my mom's 07 NAH is less aggressive about firing up the ICE after power on. If the ICE on the NAH is pretty warm (I don't have exact numbers since she has no SG), it doesn't fire up after power on, unlike on my 2nd gen Prius where will it will if you power down for more than say 30 seconds. I don't if the 3rd gen's behavior is identical.
  11. El Dobro
    El Dobro A Member
    7,102
    3,282
    Checked it again on the way home and nothing in D nor R.
  12. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    no chime. SO did it once. surprisingly, no permanent damage that we can ascertain. it was all in town driving. but have no idea how long it was on. guessing not too much as the tank mileage was normal or near enough to not warrant suspicion
  13. Tideland Prius
    16,678
    Gen 3 is less aggressive, esp. in ECO mode. I've sat for more than a few seconds and the engine stayed off after turning on the car. Of course, it will do the warm up cycle if you started it up for the first time but if it's luke warm (Again, no exact numbers), it'll stay off until you fire it up (or exceed 10mph) then it figures you're moving and can start the engine instead of having it idle like the 2nd Gen does.
    I'll take a video. It definitely chimes.
    Edit: Here's the video. All I had to do is lightly touch the parking brake such that the light comes on. No brakes were harmed in the making of the video.
    On the 2010? I don't think the Gen 2 has the chime.
  14. El Dobro
    El Dobro A Member
    7,102
    3,282
    In the USA, the word "brake" pops up, but no alarm.
  15. Tideland Prius
    16,678
    Wow.. that definitely qualifies for a post in the "Obscured Facts (way out there)" thread!
  16. Insight-I Owner
    Insight-I Owner 2006 Insight-I MT + 2011 Prius
    505
    100
    Essex, CT
    And undetectable. I don't do it in the Prius because I don't see the point of doing it in a Prius.
    It's also illegal for a driver to talk on a handheld cell in many states (including mine), but you'd never guess that from looking at the drivers of cars that go by. And doing many many other things is illegal but likewise not enforced.
  17. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ooh IC!! that is a "beep". u said "chime". i dont remember any mention of "beep"
    but wondering if its like the seat belt warning where it shuts off after a while?
  18. Tideland Prius
    16,678
    lol....
    I don't know but I don't see why it would since this could wear your parking brake down.
  19. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    In the USA, PRND is the law.
    Electronic Code of Federal Regulations:
    Nor does the Prius in the USA, the law is that it must be in Park..
  20. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    OK, then how does Toyota get around the rule about the location of the park position?
    S3. Requirements.
    S3.1 Automatic transmissions.
    S3.1.1 Location of transmission shift positions on passenger cars. A neutral position shall be located between forward drive and reverse drive positions.
    S3.1.1.1 Transmission shift levers. If a steering-column-mounted transmission shift lever is used, movement from neutral position to forward drive position shall be clockwise. If the transmission shift lever sequence includes a park position, it shall be located at the end, adjacent to the reverse drive position.
