What's a good Diagnostic App for Android?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nicoj36, Sep 8, 2015.
  1. nicoj36
    nicoj36 Active Member
    495
    158
    I have a OBD2 bluetooth that connects to my Android phone and it can read codes and reset other stuff.
    What's a good app that has many features for our Prius? One that can shut off the annoying reverse beeping, and can also do a brake bleed similar to the video below.
    Share please! Thank you.
  2. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I don't know about the brake bleed stuff, but Carista gets high marks for being able to change settings. There is a free (or trial?) version and a paid version with more capability.
    Just so you know, you can't eliminate the reverse beep, but you can reduce it to a single beep.
  3. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Try "Prius Tweak" from the play store
    XT1060 ?
  4. PlumbersCrack
    PlumbersCrack Junior Member
    45
    2014 Prius Plug-in
    You can use the same Torque app to remove the annoying beep. The Carista doesn't let you do anything decent without paying for it.
  5. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    how do you use torque to remove the annoying beep??
  6. FrankB
    FrankB Member
    117
    53
    Using 'ELM 327 Terminal' from the android store.
    I did all this with the 'Ready' light on and the doors all closed. Not sure if that is needed, but just in case you can't reproduce my results.
    After the terminal program is all connected I just typed the following commands into the little white box on the bottom left of the terminal program (not clear that this is where you are supposed to type and not very big, but it works).
    Turn 'Timer' (right side of screen above 'clear') off (or commands repeat over and over again).
    Commands:
    AT SH 7c0 (hit 'Send')
    Returns: OK
    21ac (hit 'Send')
    Returns: 61 AC 00 (meaning continuous beep)
    3bac40 (hit 'Send')
    Returns: 7F 3B 78 (no idea
    Returns: 7BAC (meaning done)
    21ac (hit 'Send')
    Returns: 61 AC 40 (meaning now single beep)
    Read more: Turn off the damn backup beep | PriusChat
    Programming a Prius to Disable the Backup Beep - Dogberry Patch
  7. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    These instructions worked flawlessly for my 2010 Toyota Prius. I just copied and pasted the commands in the little white box in the bottom left of the terminal app.
    Now to other commands that carista charges so much money for . . . . . . wink! wink!!!
    XT1060 ?
  8. AKTroy
    AKTroy New Member
    17
    Alaska
    Did not work for me. Accepted the 1st line of code, then I received an error code.I have a 2011 btw.
