what's going on with this cv axel
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Gino Veltri, Apr 22, 2023.
  1. Gino Veltri
    Gino Veltri Member
    383
    37
    I put the parts back together (minus the abs sensor) and get this noise when i put it into drive. The wheel also spins (rather quickly at first) at an inconsistent rate. Is the cv joint not pushed back into the transmission or something?
  2. ColoradoCrow
    ColoradoCrow Active Member
    967
    392
    Leawood, KS
    I
    Did you push the new CV axle in until you heard it click? I did that and then gently tapped it with a block of wood and hammer to make sure it was seated all the way.
  3. Gino Veltri
    Gino Veltri Member
    383
    37
    Honestly the axle separated from the inner cup (so the Y shaped thing with three bearings was at the inner end) and i happened to pull an axel from the junkyard the same way (minus the cup) so i left the original cup in there. I tried pushing to make sure it was in but never heard a pop or anything. I repacked the boot with red grease but those three bearing things kinda still felt crunchy like there was sand in them or something, but i dont think that would cause this.
  4. prius16
    prius16 Active Member
    462
    243
    New England
    2022 Prius Prime
    You must buy a new axle.
    Yea, money is tight for many people. However, at ~$80 for a new half-shaft, there is no reason not to buy one. Cancel Cable if you're that tight on money.
    Half Shafts parts are like internal engine parts. After break-in, the bearings are fixed to the race and the axles. You can not move bearings around, nor just mix/match parts,
    Yea, others may have done. Others have gotten stoned out of their mind, and walked naked in the middle of highway rush hour traffic. Foolish/Stupid people do foolish/stupid things.
    Last, make sure you have at least 2 lug nuts properly holding the rotor to the hub, and the the rotor is flat against the hub.
    Good Luck!
    #4 prius16, Apr 22, 2023
    ColoradoCrow and BiomedO1 like this.
  5. ColoradoCrow
    967
    392
    Leawood, KS
    I
    PLus 1. Orielys auto parts has them for $80 well worth it. Used CV axles are like a used condom. VERY bad choice.
  6. Gino Veltri
    Gino Veltri Member
    383
    37
    Hmm good to know. I just don’t think this car will ever see pavement again so I’m just learning with it.
    also those of us who get stoned and run bare as s naked in rush hour traffic like to call ourselves “ traffic jammers” and it’s actually a national pastime in Uzbekistan. Thank you very much.
  7. Gino Veltri
    Gino Veltri Member
    383
    37
    On a related note where does one sell an oem cat? Criminals seem to know but alas that life is behind me now
