What's not included in the Toyota maintenance schedule?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by TheGoshDarnedBatman, Jul 24, 2015.
  1. TheGoshDarnedBatman
    TheGoshDarnedBatman New Member
    Cincinnati, OH
    I read through the maintenance schedule, and it seems to not include a lot of things. What about brakes, shocks, transmission flushing, etc.? I'm not a big car guy, and this is my first Prius (Prius v, 2012, 40k miles.) What else should I know about?
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Drain and Fill (not Flush) the transaxle is not in the schedule. My best advice is 30,000 miles, then 90,000 miles then every 90,000 miles after that. Use Toyota's ATF WS
    If you are gentle with the brakes (and so use regenerative braking via the Motor/Generators) the brake pads last a long time. How long depends on terrain and the driver, not time or distance.
    Brake fluid flushing depends on the humidity of your driving, not time or distance.
    Shocks also depend more on road surfaces and driving attitude than any specific time or distance.
    Think about replacing the fob battery and the 12 volt battery every 4 years.
    #2 JimboPalmer, Jul 24, 2015
  3. Mendel Leisk
    38,649
    Brake inspections are in the schedule; look again?
    Shocks, bearings, CV joints are a fix them when they fail item I guess.
    Transaxle fluid change yeah: not noted, worth doing, the first change sooner, then stretch the subsequent changes. Say 25,000 miles for the first, then 50,000 miles thereafter.
    Brake fluid change has been introduced, finally, at least in the 2014 Canadian Warranty and Maintenance Guide (applicable to all Canadian Toyota models, not just Prius) :
  4. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,680
    Texas Hill Country
    Coolant around 105k. Otherwise you are good. After all you bought a Toyota, not a Hyundai. There is a reason Toyota will sell you a bumper to bumper 125k warranty.
