What's That Sound?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Witness, Jul 24, 2013.
  1. Witness
    Witness Active Member
    115
    117
    San Francisco Bay Area
    Hi All,
    You ever notice that sound coming from the driver side footwell after you powered down? After a minute or two, there's this "clunk-clunk sound" and something sliding for a few seconds. What are you doing down there PiP, I want to ask. I'm sure it's a normal routine the card does, but it does worry me that there is some kind of moving part down there that can potentially fail in the future. What is that thing?
    Thanks,
    Clunk-Clunk..ssshhh... :D
  2. Dan Cathy
    Dan Cathy Junior Member
    126
    Yeah...I get that too.
    52,806
    no, but i usually walk away after shutting down. it might be the johnson servo disconnecting.
  4. mrbigh
    3,686
    699
    Long Island, NY
    never heard the sound yet, better yet, I never paid attention .
    I would like to find out from other PC participants the origin of it
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Yup about 2-3 minutes after shutting off the car I hear that clunk. No idea what it is.
  6. Dan Cathy
    126
    In the morning, when you first open the driver side door, you should also hear another sound. It sounded like something is winding up.
  7. bisco
    52,806
    clockspring?
  8. VicVinegar
    VicVinegar Member
    275
    53
    Northern Virginia
    Yup, get both. I'm surprised it isn't covered somewhere already.
  9. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    I suspect it is the vacuum pump generating vacuum so your brake booster will function, despite the fact that there is no engine vacuum available.
  10. Dan Cathy
    126
    Sort of
  11. SLOW_RR
    SLOW_RR Member
    155
    84
    Finger Lakes Region of NYS
    Does it go.. GLUG, GLUG, GLUG, GLUG, GLUG, GLUG, GLUG, GLUG?
    No? Hmmm. Oh, that's the air pump for the brakes on the old GE 80 tonner locomotive out at the railroad museum. It's even louder than the ALCOs. Hmmm? I would tend to agree with those that think it may have something to do with the release of a pressure reservoir for the power assist on the brakes. It would also likely make a sound as it turns on upon entering the car from the drivers door....
  12. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yep! bisco, I knew Yours was a toy wind -up! and now you broke the spring! :cry:
  13. bisco
    52,806
    actually, the sound is my feet on the ground pushing the car.:cool:
  14. retired4999
    2,652
    627
    Eau Claire, Wi.
    :D (y)
  15. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    My 06 Honda civic hybrid used to make fart noises when I would brake. Always had to explain that issue to my travel companions.
    iPad ? HD
  16. retired4999
    2,652
    627
    Eau Claire, Wi.
    Ah! brake accusatory. They could be really loud. Ah Memories! :)
