What's the Best Charging Procedure?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by radiocycle, Apr 4, 2012.
  1. radiocycle
    radiocycle Active Member
    550
    78
    Vallejo, CA
    Those of you that have set schedules, commuting, school, etc. have the ideal ability to time your charging so that you can charge up right before you drive off each day. But how can I maximize battery long term life with a random type schedule? Unfortunately, ours has to live outside and we may not use it for two or three days in a row, then jump in a go somewhere.
    I understand that it should not sit with a full charge, isn't that right? So how should we try to schedule charges? Occasionally, we know that we're going up to the Bay Area and so we can charge the night before with the ending time set to end by the time we plan on leaving in the morning, but that's only every month or so. What kind of charging schedules are you guys working out??
    Thanks,
    radio
  2. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Ya' know, I think in your situation I would just drive it like a regular hybrid, and, as you say, plug it in when you know you are going to be able to use the charge, and set it to finish near your departure time. As I understand it, the two main things to avoid are charging a "hot" (recently used) PiP and leaving it sit with a full charge for an extended time. Other than that, I wouldn't worry about it. Of course you want to use the plug-in feature whenever it is convenient, but you shouldn't lose sleep over it either.
  3. SCDrJ
    SCDrJ New Member
    120
    Orange County, CA
    - Charging overnight before work, currently set from 1:30am-4:30am.
    - Arrive work at 8:00, set charge timer from 11:30am-2:30pm (to let it cool and make sure done before earliest possible departure of 3:00 or so)
    - At home, leave it be to charge overnight if I know I am in for the evening, or plug in right away if I know I will be going back out.
    I figure most of my charging (for the commute) will be using "good habits" for the battery, "cold charging" the battery closer to travel time, using up almost all the EV capacity, waiting to cold charge again before heading home.
    That said I'd rather "hot charge" before heading back out after work in the PM and in between trips on weekends so as to always have EV available if I am going to drive the car and maximize MPG... I tend to think of the Leaf and Volt owners that plug in without L2 at work, etc. who must have to hot charge (thinking drive to work, charge 8 hours if long enough drive, drive home). That and the 150k battery warranty!
    In short, I will try to cold charge if it makes sense and will not adversely affect my schedule, but will not hesitate to hot charge when I need the juice.
  4. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    There's nothing in the manual about not charging a recently use Prius Plug-in. From pg. 93 of the Owner's Manual:
    The avoiding charging a recently used Prius Plug-in was a poster's conjecture about the above. In conjunction with:
    it seems the issue is leaving the battery fully charged for extended periods of time.
  5. hill
    9,038
    Radio, there's nothing wrong with using the, "just drive it" method. Don't fret over charging/heat. Be assured .... Toyota understands fully - PiP's will be recharged in the blazing Arizona / New Mexico / Texas summer sun ... and is designed accordingly. Similarly - the traction pack is designed - knowing some folks would continually NOT charge ... while others continually seek to "top off". Modernly,manufacturers have to almost build to an "idiot-proof" standard, and thus, they try to presume any type of misuse possible - will in fact be likely. So - your good intentioned effort to 'protect' your traction pack would be better spent enjoying your high mpg's.
  6. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Totally agree.
    And actions that can harm the battery (as well as other components) are prevented by the manufacturer anyway.
  7. radiocycle
    550
    78
    Vallejo, CA
    Very good! OK, I'll not sweat it...
    Temp wise, it'll never be a problem here in 'Morbid Bay' but I do hve a tendency to want to keep it topped up. I'll just drive, and top up right before our planned outings. Thanks for the tips!
    r
  8. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    'Morbid Bay'???
    Go have a Baywood Burrito! (You can probably get there and back on a charge!)
  9. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    My charging pattern is thus: Monday thru Thursday: Get to work at 10am, plug-in to charge. Go get lunch at 1, come back at 2pm, plug-in to charge. Go home around 6:30 or 7pm, get home, set timer for 1am to start charging & then plug-in to. On Friday, I don't bother to plug-in at home until Sunday night when we get back from being out of town. No sense leaving the car plugged in all weekend when I'm not home.
  10. SCDrJ
    SCDrJ New Member
    120
    Orange County, CA
    Your mileage/week is pretty high, eh? What's your commute distance?
  11. devprius
    devprius /dev/geek
    979
    291
    92 miles round trip. Believe me, I wish it were less. At least when I go out for lunch, it's mostly EV.
  12. pip310
    pip310 New Member
    16
    New Jersey
    For me - between 8PM and 6AM or so... I've got time-of-day metering - pay much less for electricity nights and weekends.
    Now, if the charging times could be set by day of week as well as time of day that would be really nice.
  13. SCDrJ
    SCDrJ New Member
    120
    Orange County, CA
    Makes sense... I hear you - mine is 60 miles and it's about my tolerance. I was looking at your Fuelly sig and when you said you got 3 charges/day the MPG didn't make sense... until now. I think I will be low 60s for the commute, probably mid 60s overall depending on how much EV I do on weekends.
