whats the best code reader , for 11 pruis to see all the codes
Discussion in 'Prius v Main Forum' started by bobby515, Nov 25, 2025.
  1. bobby515
    bobby515 Member
    183
    43
    phila
    whats the most affordable code reader that i can buy to get all the codes.
    i think i have a bad invertor pump. i have a cheap bluetooth one.
  2. Leadfoot J. McCoalroller
    8,290
    7,803
    Pennsylvania
    2018 Prius c
    Autel AP200 or AP2500
  3. PriusTech
    PriusTech Active Member
    264
    133
    Reno
    VXDIAG VCX NANO - OBD2 interface (85$)
    Win 10 or higher laptop
    Toyota Techstream software
    This will read ALL codes like SRS and ABS etc. and a lot of other functions like ABS bleeding, key programming etc
    bobby515 likes this.
  4. PriusCamper
    PriusCamper Senior Member
    13,466
    5,433
    Pacific Northwest, USA
  5. Brian1954
    Brian1954 Senior Member
    2,688
    1,074
    South Central PA, USA
    The Autel AP200 is my recommendation. It can communicate with all 18 or so ECUs in a Gen 3 Prius. What that means is that it is capable of reading all the trouble codes, not just some of them. It can do most things that the Toyota Techstream software can do. The price right now on Amazon is $49.99 + tax. I own this model, and I also have Techstream.
    The following two linked threads are good reading.
    https://priuschat.com/index.php?posts/3248209
    Read post #1 and then scroll down to post #37 in this thread, https://priuschat.com/index.php?posts/3246758
    #5 Brian1954, Nov 25, 2025
  6. bobby515
    bobby515 Member
    183
    43
    phila
    I ordered one looks better, than what i have. after sleeping and thinking, i have the dr pruis app. rebuilt battery 2nd one in july no warrantee..cell #8 bad. i posted in tech section a topic gen 3 with photo's . thank you..
  7. Prius DIY nut
    Prius DIY nut Member
    92
    43
    Ontario, Canada
    I used Thinkdiag Mini to read all the systems and codes plus it can stream life data to my phone which was very instrumental in diagnosing a faulty speed sensor that turned my dash into a Christmas tree. Later I also got Thinkdiag with service functions (which requires subscription after first year), but I can do most of the services that pros do like programming key fobs or ABS bleed to flush braking system. I will renew subscription when any bi-directional service function is needed, but for general scanning Thinkdiag Mini was the best for all modules scanning and data streaming.
