what's the most accurate way to determine MPG ?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by fortytwok, May 6, 2013.
  1. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    No one is adding any gas to my car - its garaged, locked when out and I also have an electric mower = no gas in the garage! Wife wants no part of the PiP and hasn't even driven it.
    But - you bring up an interesting point - idling. I assume you mean those awful times ICE kicks in.
    I am rarely out of EV range and I've been keeping a log - some weeks the only gas "used" has been those 120 mile intervals when ICE kicks in...
    I maintain the system that says 6 gallons is off - 3 gallons per gas bars correct given 192 miles (20 were dealer miles).
    Pic coming later although I don't see what that would show
  2. El Dobro
    El Dobro A Member
    7,075
    3,258
    A week ago, I ran the gas down until the last pip was flashing and the readout said I had 14 miles to go before empty. When I filled up, the car took 8.136 gallons, so there were probably around 2 gallons left.
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    There was a previous post from a member wondering why he got terrible fuel economy. He drove 20 miles a day and charge every day and got 54 mpg as I recall. Say what? He posted a pic and it showed his kWh was the equivalent of 20 days worth of charge (I'm making up these numbers as I don't have a forum search function on my iPod). He had owned the car considerably longer than 20 days. So for whatever reason electricity wasn't going into his car.
    There was also the guy that said he got 20 mpg. Turns out it was 200 mpg. It's a lot easier to troubleshoot with the data instead of asking you a bunch of questions.
  4. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    I promise I'll take pics and post in a couple hours !
    but everything else is in synch - bars show the max - 200mpg
    I've kept a log and know I'm over 700mpg - I'm at 2350 miles / 91% EV / 3 bars down ! Even if you want to round up and say the 3 bars mean 4 gallons that'd = 600mpg. I'm semi retired - I just coach at the local high school so I simply don't drive out of EV range on my 4 trips a day.
    The only thing out of whack is the read of 6 gallons - even ICE kicking in every 125 miles wouldn't get it there...
  5. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Just to be clear (because I think there is some confusion on this point), when you say "3 bars down", you mean you have 7 bars REMAINING, and have only used 3 bars correct?
    If that is the case, something does seem off. I dont see how the EV/HV ratio screen could say you used 6 gallons when you have 7 bars remaining. The only scenario I can think of is your car, prior to you driving it off the lot, had consumed 2-3 gallons of gas. The trip meters were reset when you bought the car, but the EV/HV ratio was not.
  6. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    correct - as shown in the pic I posted - 3 bars down means I have 7 remaining
    and no - driving it off the lot my car had never been in EV mode. They just didn't charge it for my test drives.
    It did have 20 gas miles on it and then they filled up for delivery to me.
    As problems go this isn't that bad, I'm just surprised given technology these days
    edit - to be clear - my PiP had 20 gas miles on it at pick-up AND odometer read 20 miles
  7. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    Here's the pic taken just before hitting 91% - hopefully its readable - was hard to squeeze in the readings and show the gas bars
  8. 3PriusMike
    3,094
    2,417
    Silicon Valley
    I see no picture. Are you sure you are uploading correctly? There is an icon for an image in both of your last 2 posts...but no pict.
    Mike
  9. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    it was in my sig but here's a copy :
  10. SLOW_RR
    SLOW_RR Member
    155
    84
    Finger Lakes Region of NYS
    So how exactly do you put a photo in your signature?
  11. SLOW_RR
    SLOW_RR Member
    155
    84
    Figured it out....
  12. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    not sure what that means - Is the pic not showing up properly ?
  13. El Dobro
    El Dobro A Member
    7,075
    3,258
    No pics, just the dreaded red X.
  14. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    trying again !
  15. El Dobro
    El Dobro A Member
    7,075
    3,258
    Are you using the little tree icon to insert your image?
  16. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    I've been unable to do that "little tree" option - so I cut and pasted (which apparently didn't work either)
    Odd as I'd done that before from my Iphone. I did manage to post pic on my avatar - not the greatest but if you squint you can see the numbers
    and here's using a photo service :
    http://s1329.photobucket.com/user/golfx15/media/photo_zps5a350369.jpg.html
  17. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Easy Peasy.
    Fill up the tank to the brim; Measure amount required
    Remove a gallon;
    Repeat measurement as desired.
  18. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    thats not desired - and why I purchased the PiP ;-)
    I'll get my first fill-up in a couple months, just wondered if anyone here saw a disconnect with the remaining "gas bars" and the reading that showed gallons used...
    PiP 2350 Photo by golfx15 | Photobucket
  19. mmmodem
    2,732
    1,703
    Bay Area, CA
    I see the pic. I don't see anything obvious. All we need now is the odometer and the calculated fuel economy from the car.
    If it is the same distance or close to the same distance as your combined EV ratio then we can infer that those 20 dealer miles used up 2-3 gallons of gas. In other words, the dealer and test drives used up 2-3 gallons. Maybe they left it on idling by mistake, some members have done that. You buy the car and tank gets full but the EV Ratio is not reset.
    This is pure speculation on my part.
    Tracksyde likes this.
  20. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    pic of Odometer photo_zpse4cb6bbd.jpg Photo by golfx15 | Photobucket
