What's the most difficult catalytic converter protector to cut?
Discussion in 'Gen 2 Prius Main Forum' started by pri4u, Dec 1, 2022.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,615
    773
    Southern California
    Does anybody sell a heat tolerant paint on abrasive coating? I know there are paint on anti slip coatings, but I doubt they would stand up to the heat right next to a catalytic converter. In any case, the idea would be that any cutting tool blade/bit would be quickly ruined by the carbide (or whatever grit is used) in the abrasive coating.
  2. pri4u
    pri4u Member
    113
    Is it true if you park on a hill, they need to jack up your car. If it’s on a hill they risk the jacks shifting and the cars falling on them. They’ll move on to a less dangerous target. If living in a non-hilly flat surface area, is there a way to position/park the car in a way that would pose a risk to those who will try to jack it? Will some sort of platform material could be placed on a flat surface parking spot so the car will be parked on it?
  3. pri4u
    pri4u Member
    113
    Do you actually have proof that such material would cause the blade/bit to be quickly ruined? i.e. similar to the youtube video on this thread for using the latest electric saw products (i.e. sawzall, diablo, etc) against it?
  4. pasadena_commut
    2,615
    773
    Southern California
    Not sure how quickly, but faster than pure metal. I'm assuming the thieves use metal cutting blades, and those are not intended to rip through abrasives. There are sawzall blades for cutting concrete and other abrasive substances which wouldn't care about the coating, but they might not do so well on the metal then. The optimum "no cut" material would be some sort of repeating sandwich/honeycomb of metal parts filled with something like diamond dust embedded in concrete. There are research materials along these lines which are said to be nearly impossible to cut (without changing blades/wheels frequently), but I'm not aware of any of these being available commercially. For instance:
    Engineers Develop Material That Cannot Be Cut - ExtremeTech
    I have never tried it, but a layer of asphalt over metal might also be a problem for a sawzall. It isn't that the blade won't go through it, but the asphalt will coat the sides of the blade and it will then probably jam in the groove.
    SFO likes this.
  5. MufflerTech
    MufflerTech New Member
    Sacramento
    If anyone is interested, we are offering a set of 4 Locking Exhaust Bolts with Key for $150 shipped to any of the lower 48 states. These bolts with a shield are a game changer for protection on these vehicle. Give me a call anytime 916-421-0399 and or check out this helpful link for info on what these locking bolts look like, how they are so effective and where they are located.
