Whats the most you've hauled in your prius?
Discussion in 'Gen 2 Prius Main Forum' started by parrot_lady, Jan 30, 2006.
  1. lech auto air conditionin
    830
    605
    261
    san francisco
    yep that sounds exactly like me. just remember to change the transmission fluid a lot more often I’m trying to devise a way where I could do quick transmission fluid changes possibly by drilling and tapping through the case.
    One of the secrets to long life on smaller vehicles even larger vehicles when you constantly overload the weight limit load changing your transmission fluid every 20,000 miles or so and if you have a rear end or front end differential constantly changing differential fluid it becomes easy to get that 300,000 or 400,000 miles. Never allow the breakdown from heat and your clutch packs to create that burnt varnish and the small micro metal particles that continuously float around like 3000 grit sandpaper in your system keep it well diluted down greatly extend the life of transmissions and ruin differentials.
  2. Kaptainkid1
    Kaptainkid1 Active Member
    308
    247
    Los Angeles
    35 case of water 1300 lbs of water. Almost destroyed my suspension. 20200227_090439.jpg 20200227_090432.jpg
    SM-J737T1 ?
