whats the noise when backing up and no not talking about the beep
Discussion in 'Gen 4 Prius Main Forum' started by MikeV, Nov 24, 2023.
  1. MikeV
    MikeV Junior Member
    95
    philadelphia
    curioius what the noise when in reverse that sounds like water running through pipes. i never notices that on my gen 3 and not sure i noticed it on my gen 4 right away but now i do. i had the car in reverse but stopped for about a min to see if it went away but did not. as soon as i switch to drive it goes away
    49,515
    i would have said the pedestrian warning system, but it should be the same in forward or reverse, up to about 15mph or so.
    you won't likely hear it after the engine comes on, or if the windows are up out in open space.
    i always hear mine pulling in and out of the garage in ev.
  3. MikeV
    MikeV Junior Member
    95
    philadelphia
    no this sounds like water pipes filling back up after the water had been turned off but it makes that sound until engaging Drive
    49,515
    what year and mileage?
  5. MikeV
    MikeV Junior Member
    95
    philadelphia
    21 22k
  6. Harters
    Harters Active Member
    335
    424
    UK
    Excel
    Can you do a video, so we can hear it for ourselves?
  7. MikeV
    MikeV Junior Member
    95
    philadelphia
    yes ill do that sometime this weekend
    Harters likes this.
  8. MikeV
    MikeV Junior Member
    95
    philadelphia
    yes ill do that sometime this weekend. I wonder if the cold weather has something to do with it because I bought the car in Aug and havent noticed it prior until recently when temps were below 40
  9. MikeV
    MikeV Junior Member
    95
    philadelphia
  10. Doug McC
    Doug McC Senior Member
    1,006
    377
    Midwest
    2022 Prius
    On my ‘22 the Proximity Notification sound is significantly louder in reverse than in drive, and it seems to be slightly different (but I think that just may be because of the volume). I never thought of describing it like you have, but I believe you could.
  11. bisco
    49,515
    maybe it's a coolant heat pump, but should be the same in both directions
  12. Bob Welcher
    Bob Welcher Junior Member
    Columbus Ohio
    I noticed a rhythmic humming sound when in reverse when I bought my 2021 Prime. I took it to the dealer and was told that the sound is normal for the Gen 4 Prius. If you raise the hood, you should hear the sound toward the front of the engine compartment. If in doubt, take it to a Toyota dealer and have them check it out. Most dealers will check it out for free.
  13. MikeV
    MikeV Junior Member
    95
    philadelphia
    heres the video clip. disregard the backup beep listen to the other sound
    Ive heard a similar sound when someone was backing up their 2017. much louder. I thinks its the ev motor. //i have an mp4 video clip but cant seem to upload here, any suggestions on that
  14. bisco
    49,515
    the uploads were broken in the recent server migration. who knows when they'll get fixed.
    some have had success uploading to another site and providing a link
