What's the part name for the trim under the radio/CD changer?
Discussion in 'Gen 2 Prius Technical Discussion' started by Banksy, Apr 23, 2020.
Tags:
  1. Banksy
    Banksy Active Member
    415
    132
    Lancaster Pennsylvania
    So the storage compartment trim or whatever you call it under the radio in my Prius is pretty rough.
    I have tried sanding it and using clear coat for plastics but I'm curious to know if it might just be easier to replace it.
    do not know if you can buy them anywhere or what the part/ piece is actually called
    Anybody know where I could possibly get a replacement?
  2. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    George W, ydpplqbd and SFO like this.
  3. R-P
    R-P Active Member
    804
    288
    Netherlands
    Curious what it costs. My 5568x (last digit falls off on the right-hand-side of the pic, the fan-opening-part on the right side of the radio) is broken due to previous owner cutting a hole for his carkit. I think it was something like 270 euro's (~300$) for that piece alone.
    Suddenly the crack and the hole don't bother me anymore...
  4. MickyMatter
    260
    168
    Germany
  5. R-P
    R-P Active Member
    804
    288
    Netherlands
    Thanks! I think that is the correcct one.
    I bought some spare part for the Prius once and was baffled by the low price (unfortunately I forgot what, maybe the lock on the fake boot-floor?), so I had expected the trim piece to be something like 50euro's max new.
    59euro is not too bad, but I'll hit the local junkyards first. I drilled a hole in the sidepanel of the boot for a plug to charge the HV battery, but I have since changed plans, so getting such an extra panel would be nice too.
    #5 R-P, May 1, 2020
  6. MickyMatter
    260
    168
    Germany
    How do you (plan to) charge your HV battery?
    SM-G950F ?
  7. Mendel Leisk
    40,555
    Try removing it and spraying with black Plasti-Dip. It gives a slightly textured, satin finish, not bad.
    MickyMatter likes this.
  8. Banksy
    415
    132
    I actually ended up sanding it down and using clear coat for plastics
    Came out pretty nice!
    Mendel Leisk and MickyMatter like this.
  9. Mendel Leisk
    40,555
    I managed to dig up some example pics, so anyhoo:
  10. R-P
    R-P Active Member
    804
    288
    Netherlands
    I was going to rectify all nine different AC voltages on a massive toroid transformer and then series wire my powersupplies with currentlimit. This would allow me to charge from 50 to 250V with a currentlimit of e.g. 300mA (I would have to rewire after every 50V increment but I would be able to charge with up to 4A).
    But then I bought a PowerPac 1000. It is a 5V-1000V 500mA adjustable powersupply with a currentlimit. Charging will be slow, but fully controlable.
    #10 R-P, May 2, 2020
