Whats the wisest way to Use the EV switch?
Discussion in 'Gen 2 Prius Main Forum' started by windstrings, Feb 13, 2006.
  1. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    You're welcome.... my wife keeps calling my car the "Hot Tamale" and hers "The Mint Julip".. :lol:
  2. driveprius
    driveprius New Member
    112
    Delaware
    Assuming the weather wams up above 32 deg F then the reason you might want to leave some charge in your battery when parked is that you can still use EV to avoid the gas mileage hit of warmup. When your gas engine is burning up gasoline your car needs to be moving. The faster you can get your car coasting while keeping it running gently the better. If you drain your battery than you've committed yourself to a long period of getting zero mpg. The only exception to this rule is if you know that once you start your car you are not going to be stopped at any traffic lights for the next 3 minutes.
  3. driveprius
    112
    Delaware
    The EV switch could get you past the aggravating situation of having your engine idle senselessly. If it's below freezing for many hours then of course the EV switch is useless to help your morning warmups because your EV request will get rejected. If you park your Prius during mid day than even if it's below freezing often the EV mode will work for startups. For the mid 30's or higher than it becomes very useful.
    However, if you drain your batter too low than you'll never get to know the benefits of EV to aid your morning starts because the EV mode will always get rejected.
  4. driveprius
    112
    Delaware
    I basically follow everything you do. In addition I sometimes use EV to assist acceleration from a standstill up to around 15 mph. Then I pulse the gas to kick out of EV mode and continue with the gentle acceleration. My general goal is to always avoid getting my display to ever show below 10 mpg. From my experience if I am frequently unsuccessful in avoiding single digit displays during acceleration I will end up averaging in the 40 mpg range. If I am successful I'm well on my way to the 50's.
    I used to think the best approach to maximizing mileage is to get long periods of 99.9 mpg. But what I find is that the biggest factor is to minimize the amount of time you spend in low mpg. In the mathematics of average gas mileage it only takes a tiny smidgen of single digit mpg gas mileage to wipeout the benefits of stretch of 99.9 mpg gas mileage.
  5. windstrings
    6,280
    378
    Central Texas
    yep, I agree.... I sometimes thing the average calculator waits to calculate..... sometimes I'm getting phenominal mileage and it doesn't seem to impact it to the positive, but then other times I'm getting crappy mileage and it doesn't hurt me much...
    Oh well as long as it comes out in the wash I'm good.
  6. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    For me using ev at night is best. Couple of extra reasons that don't apply for everyone: It is cold here so ev has very limited current capability in the mornings, except in summer. Often too cold for EV first thing in the morning. Also though I would like to delay start up, have some coasting, and lights to wait at there is one hill that is a bit steep for ev and the engine usually starts up on that hill if I try to delay startup. So for me it is way better to use ev at the end of trips.
    Also at my end of trip, engine will normally be off anyways. The EV mostly just keeps it from starting up to keep warm, and fuel use for more heat would be a waste when about to shut down.
  7. windstrings
    6,280
    378
    Central Texas
    usually the engine will never idle senselessly unless its trying to warm up or you have the auto A/C on.
    Turn off the AC and the auto and just let the recirc be on... the vents will still work to make the temp what you want and you will save energy and the ICE won't keep coming on.
    The only reason I can think of why you may need to turn AC back on is when it gets hot outside to engage the air compressor for cooling.
    Until then when all you really need is to warm, the convection of the air blowing over the heater coils will suffice.
