What's this?! from a new review
Discussion in 'Gen 5 Prius Main Forum' started by Downrange, May 26, 2023.
  1. Trollbait
    12,835
    I only recall it in the marketing material. I can't think that such a plastic shield would actually be needed. At least for what Toyota would charge for it. You can almost close the window on the cord. Maybe even safely close the door or hatch on it. Depends on the cord, and you can find flat ribbon ones.
  2. Exerted
    Exerted Member
    110
    100
    2023 Prius Prime
    It's kind of cool that the Prime has these residential outlets. Curious what's the best case use for them? In an outage it would be great, but any other ideas?
  3. mountaineer
    mountaineer Active Member
    146
    115
    Hamilton, ON
    2019 Prius Prime
    Camping. Tailgate party. Picnic electric grill. Inflatable kayak pump. Mobile office (with cell service you can work anywhere). Outdoor power tool use. Electric cooler for a long car trip – or grocery shopping in the summer when you'll be out all day running errands. Vendor power at an outdoor market or fair. Improvised drive-in movie theatre (they provide the parking lot & wall, you provide the projector & FM transmitter). Vacuum cleaner for that sunny day you're cleaning out the car. 1500W unlocks a lot of possibilities – pretty much anywhere you'd use a portable power station or generator.
    My favourite is having a powered cooler in the trunk that's just there all summer. Most are 12V, so will need an adapter. Curious whether the outlets are powered all the time, or do you have to turn them on?
  4. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    I’m envious now. :sick: Finally found the emojis. :)
  5. Exerted
    Exerted Member
    110
    100
    2023 Prius Prime
    There's a switch on the lower left side of the dashboard
    mountaineer likes this.
  6. Gokhan
    Gokhan Senior Member
    6,718
    2,672
    Paramount CA
    The window gasket is a separately sold accessory as far as I know.
    Yes, the AC outlet can be used as a generator output either with the PHEV battery or ICE.
  7. mountaineer
    146
    115
    Hamilton, ON
    2019 Prius Prime
    Have you decided which way to go for your vehicle?
  8. daisy555
    1,729
    716
    CT
    Well the Prius XLE AWD is on its way. : ) I’ll have to adjust the seat all the way up or get some sort of an angled pillow. Goal is to sit as high as possible without the steering wheel sitting in my lap.
    If I can’t make it feel comfortable, the Corolla Cross hybrid is a back up plan but I’d have to wait another couple of months. I’m not someone in the financial position to trade in a new car within two years but depending on my experience and what’s available I might have to.
    My 2009 is making a noise that got a bit louder after some majorly bumpy highway driving through NYC. It supposedly isn’t wheel bearing. I don’t want to put any more into this car so waiting for the Corolla Cross hybrid might be a risk I shouldn’t take. Time will tell!
  9. ColoradoBoo
    ColoradoBoo Senior Member
    1,356
    984
    Monument, Colorado USA
    Don't get too excited over a 120v outlet in a vehicle. My 2005 Tacoma had one in the bed and I was excited to be able to use power tools but quickly found out the amperage is pretty pathetic...even while the truck was running.
  10. Downrange
    Downrange Active Member
    373
    214
    2024 Prius Prime
    SE
    Nope. The Tacoma was a low power inverter, maybe 300 watts. The Prime uses the traction battery with maybe 1000 watts or more available. That's enough to power most handheld power tools, or your freezer and some light in a power outage.
    ColoradoBoo likes this.
  11. AndersOne
    AndersOne Active Member
    346
    200
    Europe
    2023 Prius Prime
    In europe it has 1500 watts - that should be even enough to blow dry you hair if you have to. I guess outside of europe its the same...
    EDIT: Nevermind, was posted already anyway - interestingly in europe there is only one outlet in the back though.
    ColoradoBoo and Downrange like this.
