What's this Noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dongfang, May 11, 2018.
  1. dongfang
    dongfang Junior Member
    36
    I have a 2006 Gen2 Prius (271K miles), for about 5 years. Since last summer, the fuel economy become worse, from annual 46 MPG to Winter 30 MPG & Spring 36MPG. I noticed there is some grinding noise that the sound volume grow with car speed.
    Today I lift each side front wheels, and I'm able to identify the noise come from left front wheel.
    What this noise it is? (I believe it is not bearing noise, as I have replaced both front bearing in recent years.)
    The sound Video:
    Right front wheel Lift (Good):
    Left front wheel Lift (Noisy):
  2. JC91006
    16,936
    8,646
    Sounds like something is rubbing
    jerrymildred likes this.
  3. dongfang
    36
    But the sound was there for several months...
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I agree.
  5. RRxing
    RRxing Senior Member
    2,562
    1,840
    NEPA
    Looks like your parking brake is on...
  6. jerrymildred
    11,517
    14,167
    Tampa, FL
    I sure hope so. He had one front wheel off the ground so it would rotate. ;)
  7. JC91006
    16,936
    8,646
    I would make sure you caliper glide pins are properly lubricated
  8. dongfang
    36
    Thank you for your information! I will check it.
