What's this?
Discussion in 'Generation 1 Prius Discussion' started by C Clay, May 10, 2014.
  1. C Clay
    C Clay Member
    409
    82
    Lexington, KY
    2019 Prius
    L Eco
    This was dragging on my daughters car today. I can't see why it needs to be reinstalled.
    52,904
    looks like some kind of protective plate. might be something sensitive to road damage above it.
  3. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    My guess would be a heat shield.
    If the car is never parked over a pile of dry leaves or pine needles.......then you might not need it.
    If it IS parked over something combustible sometime, you might be VERY SORRY if it is not still in place.
    A car on fire is not a pretty thing. :(
  4. C Clay
    C Clay Member
    409
    82
    Lexington, KY
    2019 Prius
    L Eco
    The fact that it's flimsy plastic is what had me wondering.
  5. bisco
    52,904
    could be to help with aerodynamics and provide better mpg's. newer models are more extensive.
  6. Easy Rider
    982
    210
    N. Central Florida
    "Plastics" can be designed to do all sorts of things.
    So.....what is behind that plastic flap ? Or above it, depending on your perspective ??
    If it is any part of the exhaust system, I definitely would replace it.
    Can't be THAT expensive; it's just "flimsy plastic" right ?? :)
    It might be interesting to have a dealer's parts guy look it up and see what it is CALLED.
  7. C Clay
    C Clay Member
    409
    82
    Lexington, KY
    2019 Prius
    L Eco
    Yep- I could see that except for it has holes in it
