Whats under the rear seat?
Discussion in 'Gen 3 Prius Audio and Electronics' started by jdjd, Dec 24, 2010.
  1. jdjd
    jdjd Junior Member
    illinois
    Is there any room at all under the rear seat for Subs or amps? If so how much and what exactly is under the seat? Thanks...
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    The High Voltage (electric traction) battery is under the rear seat.
  3. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Directly under the seat is the gas tank.
  4. cossie1600
    cossie1600 Active Member
    898
    92
    CT
    I don't recommend it, great way to catch fire trapping all the heat
  5. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    It's not under the rear seat. It's behind it.
  6. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Thanks. Since you have to remove the rear seat to gain access to the battery, I thought the battery was partially under the rear seat.
  7. acmesign
    acmesign New Member
    Peoria, Arizona
    I use my Prius for deliveries and have taken the rear seat and passenger front seat out. Pretty easy removal....just a few bolts. Not much extra room under rear seat; probably enough for your amp but definitely not subs. Stock amp is under the front seat under a plastic cover.
  8. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    You don't have to remove the seat to get to the battery in gen3, just pull up the cover above it in the boot.
  9. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    HV battery is behind the rear seat back, under the hatch area floor.
    Found lots of references to removing the rear seat bottom on the 'Net,
    but can't find a pix with the rear seat bottom removed anywhere.:mad:
