What's under thte fog lamp covers?
Discussion in 'Gen 3 Prius Main Forum' started by grahamy, Jul 16, 2009.
  1. jaywolf
    jaywolf Member
    107
    Vincennes, IN
    I be willing to price set.
  2. Martin37
    Martin37 New Member
    200
    23
    Joseph, Oregon
    Since I have to have my front bumper replaced (see "Mattresses and Priuses ..." & "Body repair estimate ...") I will inquire about the added cost of painting those grey plastic foglight covers with the same auto body color. It shouldn't cost too much, do you think? :thumb::pound:
  3. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I won't even have the car until 7/27.
    Can anyone tell me how easy it is to remove these pieces OR maybe even post pictures of them?
    Once I see them I might be able to determine if they should be fiberglass or plastic. I've also sent a message to a guy I know that makes automotive plastics.
    Thanks!
  4. patsparks
    10,664
    569
    Adelaide South Australia
    How far is Oregon from West Virginia?
    Could Martin37 send the ends of his bent bumper to you to use as a dummy bumper?
    I don't know how damaged it is but ...
  5. drees
    drees Senior Member
    1,782
    247
  6. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    I'm sitting here laughing. All this clutter about fog lights, when the reality is in North America it is -ILLEGAL- to have proper fog lights. The law says in Canada and the US the headlights must be on when the fog lights are on. No point then in having lamps that doen't reflect back at you when the headlamps, which do reflect back in fog, have to be on!
    Looks to me like you are all "spinning your wheels." ;)
  7. DaleR
    DaleR New Member
    Suwanne, GA
    I would like to have day time running lights (especially LED) in the fog lamp space. Anyone have any ideas on how to do that?
  8. paulemus
    paulemus New Member
    93
    San Diego
    For $22 at Napa, I got a couple truck LED lights with boots. Used a knife and file to gradually get the size right. Unbolted bottom cover for access. Attached wires to top marker light. See manual for removing a couple pieces on passenger side.
      File size:
      3.3 KB
      505
      File size:
      3.5 KB
      488
      File size:
      2.4 KB
      501
  9. silverfog
    silverfog New Member
    152
    23
    Raleigh,nc
    Two gaping unpainted holes -- to be exact. However, it's not a big deal to buy the Prius V foglight covers -- about $80 as I recall. Then install the Prius fogs or a suitable alternative. The problem with cutting holes and fitting fogs into those horrid blanks is that the alignment is not right. As for practicality I believe it's far better to install your own fogs with independent switch rather than have them wired to the headlights -- not only do you have much more effective lighting for actual fog, but you also have the option of using them as daytime running lights.
    However there are several threads on this very subject somewhere in this forum.
