What's with exclamation mark sign?
Discussion in 'Gen 3 Prius Main Forum' started by nudriver, Jan 26, 2020.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Wrong. No problem. With synthetic, the interval is 10k miles or 12 months, whichever comes first. What you can't do is wait that long to check the oil. I would check it weekly till you get a feel for how fast your car is burning it.
    See my previous sentence.
    Yup!
    Probably considerable damage even before your adventure and now it's worse. Plus, if it burns oil badly enough, it'll eventually ruin the catalytic converter, too. No har in driving it till it dies, but just know that it's on borrowed time.
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Runs fine but on borrowed time, you’re correct.
  3. nudriver
    nudriver Member
    283
    32
    los angeles
    Kind of doubt it. Car's in great shape and people probably do this all the time. Not everyone who owns a Prius is as car-centric as some of the people here.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Meaning people get low pressure light when doing turns and let oil level go all the time? Verdict has ruled against Jerry Mildred.
  5. fuzzy1
    10,719
    There should have been no problem whatsoever in waiting 6 months (or even a year, if miles don't rack up) to change the oil. The problem was waiting that long to check the oil level.
    That wasn't just a top-off, it was a refill. If you want to keep this engine, don't wait 2000 miles to check it again. Check much sooner than that, then only if it isn't done far will it be safe to wait longer intervals,
    Just "... a bit ..." ??o_O It seems that you are still missing something here. When you don't see oil in the dipstick, you had waited much too long.
    Numerous PC posters encountering this issue have subsequently found permanent high oil consumption. So be sure to monitor the oil level frequently,
    #45 fuzzy1, Jan 28, 2020
    jerrymildred likes this.
  6. fuzzy1
    10,719
    Yes, numerous people do this all the time. And many of them run into problems, greatly helping keep auto mechanics and dealers in business.
    And this is not at all Prius-specific, it happens in all other cars too. BMW had such a serious problem with drivers not bothering to check and then suffering engine damage, that they abolished the dipstick altogether and put in a special oil level sensor. Though disappointment from other drivers has caused them to start bringing back the dipstick.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    I guess you really ARE a new driver after all.
    Oil is lost by being "burned" by the engine, which goes out the tailpipe in the form of smoke OR from a leak.
    Even if it is from a leak, some leaks only happen while the engine is running.
    The lack of a puddle of oil where you park means pretty much NOTHING.
    Check the oil.
    Montgomery and Grit like this.
  8. jerrymildred
    11,517
    14,171
    Tampa, FL
    That's probably true. And not everyone who ones a Chevy, or a Ford, or any other car. But if you're not "car centric" enough to check your oil, you're in for an expensive driving experience.
    In fact, since you seem to imply that there's something a little weird about people who take care of what's probably the most expensive thing they own, I'd go so far as to say that if you're not "car centric" enough to check the car's oil, you're not "car centric" enough to be driving one. My parents taught me to take care of my stuff, and a car is pretty expensive stuff.
    fotomoto likes this.
  9. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    What happens if I have a beater that was purchased for $1,000? :p
  10. jerrymildred
    11,517
    14,171
    Tampa, FL
    Same thing but more so since you'll probably be replacing engines even more often. Unless it's worth $1,000 every so often to save a few seconds checking the oil. :ROFLMAO:
    And you like shopping for beaters. LOL!
    fotomoto and Grit like this.
  11. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    I looked, but didn't notice, did you check your oil yet?
    Maybe I missed where you checked the oil, using the dipstick, in the last day or so?
    So, did you check your oil? ????????? :rolleyes:(n)
    Cosmo Tigato and jerrymildred like this.
  12. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    Wrong...you can wait for 7-10k miles to change the oil,,,,just don't wait that long to CHECK IT !!!
    ASRDogman likes this.
  13. bettergolf
    495
    370
    Sanford NC
    What's the problem here? Why should any car owner need to check anything? That's what the warning lights are for, right? Same for gas...no need to look at the gauge, a light will come on and you will start hearing a dinging sound when you need gas. Everybody does it. (and there's another new thread on here where someone else didn't check their oil and is getting a warning light.)
    You guys here are just car nuts wanting to check the oil and doing maintenance and such. They don't do that in California. They just take it to the shop when it needs oil.
    Check oil, change oil....whats the difference?
    And he still wants to argue....let him blow his engine. He probably would think he just got a bad engine, they shouldn't lock up just because they need oil!
    wow.
    Montgomery, Ed Beaty and kc5dlo like this.
  14. kc5dlo
    kc5dlo Active Member
    266
    164
    DFW TX
    2021 Prius
    Unable to delete post.
    #54 kc5dlo, Jan 28, 2020
    Grit likes this.
  15. ChapmanF
    19,041
    At the stage in my life where that was what I was driving, it was still among the most expensive things I owned.
    I would scout out the slightly elevated places to park, where it would be easier to push start while I earned enough for a newer 12 volt battery.
  16. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    No need for personal attacks.
  17. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Wouldnt be prius chat w/o any :ROFLMAO:
  18. fuzzy1
    10,719
    Then it just wouldn't be him.
    jerrymildred, Johnny Cakes and Grit like this.
  19. jerrymildred
    11,517
    14,171
    Tampa, FL
    Yeah, there are a couple here channeling Don Rickles. :whistle:
    Montgomery likes this.
  20. sam spade 2
    7,035
    2,804
    2017 Prius c
    Maybe you should tell that to the Donald. :eek:
    I just call them like I see them.
    I strongly suspect that a LOT of others have similar thoughts.
    Everybody is ignorant about some things but when you keep harping away at it, then that slides over to stupid. It is important to know your own limitations........especially when others point it out to you.
