What's with the Prius's hub caps?
Discussion in 'Gen 3 Prius Main Forum' started by Skoorbmax, Mar 28, 2010.
  1. good-sort
    good-sort New Member
    US
    Please Help ... I need a wheel cover (hub cap). Mine flew off and someone ran it over.
    If there is anyone who is no longer planning on using your wheel covers -- can you please let me know.
    Thank you!!
  2. mspivak
    mspivak New Member
    Well, I'm one of the Prius owners that think these hub caps are "butt ugly." I removed them from my 2010 Prius and purchased four center caps from Toyota to show off the really nice alloy wheels underneath.
  3. Tom183
    Tom183 New Member
    652
    65
    Maine
    "Alloy wheels" is one of those searchable terms which gives a vehicle the ability to fetch a higher price. The hubcaps are for aerodynamics and could have gone over steel wheels - which don't have the same selling power...
    I like having the option of either the open look or the aerodynamics - I just wish Toyota could have thrown in a set of center plugs...
  4. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    Here an answer I got on Facebook for Toyota Canada
    That's a good question Mark, and it comes up often. The reason the Prius has the plastic hub caps is to compensate for air turbulence caused by the spinning wheel. This turbulence can affect the aerodynamics of the vehicle, so these hubcaps actually help reduce the turbulence and improve overall fuel efficiency
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Lots of people are selling them on eBay.
    I wonder why?:D
  6. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Thanks!
    So basically it sounds like they engineered a poorly designed standard aluminum wheel and then realized that the only way to "fix" it was to put slabs of silly plastic on. Or alternatively they knew before hand what they'd end up with but without plastic slabs a prettier aluminum wheel with similar aero qualities would cost too much to make.
  7. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    If they were full wheel covers instead of 5-spoke wheel covers, I would give that Facebook statement some credibility.
    Or if they even threw in some numbers from an official Toyota technical source.:eek:
  8. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    A 5 spoke wheel should cost less to cast or forge than a 10 spoke wheel.
    Another possibility is that someone at Toyota decided at the last minute that the II-IV models shouldn't have better looking wheels than the V so they kludged up some ugly 5 spoke plastic covers for the II-IV
  9. Tideland Prius
    16,676
    No. They engineered a lightweight alloy and used plastic to fill in the design (note how the 3G Prius has twin spoke alloys instead of the solid 5-spoke of the 2G).
    Also, the 1G Prius has wheel covers too. It's only the 1.5G that we had over here that had fully machine-finished alloy wheels (multi-spoke) without covers.
    Besides, it's like having two rim designs!
    Sounds exactly like what the Chief Engineer told us ;) (and what those of us who were at Detroit said)
  10. johalareewi
    johalareewi Member
    393
    44
    uk
    When I had my first service, the dealer's service manager noticed that the hubcaps were missing and asked if I had taken them off. He then said that I should put them back on because they were there to cool the brakes. :confused:
    Can't see how that would work because the brakes don't get a lot of work anyway so aren't going to get hot and if the hubcaps channeled air to the brakes, there would be a left hand and right hand set and all four of mine are exactly the same.
    Anyways, they are still off. :cheer2:
  11. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    Can you post pictures of these caps installed on your rims?
  12. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Google is your friend
    42603-52110 - Google Search
    Google often has results for car part numbers
  13. Paul58
    1,126
    125
    Atlanta
    Who'd a thunk? I did Google the part number, but didn't think to look at Google Images. I just had a bunch of parts distributors pop up, and none of them had pictures! Thanks...
  14. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    The GIII comes with -wheel covers-, not hubcaps. The post above with the google link is for hubcaps. These are very similar to the GII hubcaps on the non-touring. Toyota uses a few slightly different designs, as you can see in the link. If they all fit the same diameter hole I'll be floored! ;)
    The "hot setup" for the GII touring was to remove the "wheel covers" and install the "hub caps". For looks only, of course.
  15. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    For anyone interested, here's my summary of the Toyota center caps known to fit the 2010 Prius 15" wheel:
  16. Downrange
    Downrange Active Member
    373
    214
    2024 Prius Prime
    SE
    The Toyo caps look nice, but you can get the 2 inch electrical panel plugs at Home Depot for a buck each! Bend the tabs out a little and they pop right in. 4.00 vs. 40.00. Takes yer choice!
  17. Skoorbmax
    2,641
    265
    Western NY
    I can't imagine brake cooling is of any relevance at all on this car. Mine are hardly ever even hot. You'd have to be autocrossing to warm these things up thanks to regen braking.
  18. Prius Team
    Prius Team Toyota Marketing USA
    681
    1,817
    CA
    Bingo. Keep in mind our engineers scrape for .01 MPGs so they can achieve their targets (in this case, 50 MPG). So you might not notice a lot of these improvements individually, but they are very important to achieve the overall goals.
    Definitely the latter, but it's also a weight issue. Tideland nailed it in his post. Think of the alloy wheel underneath as simply the minimal structure needed for wheel stiffness. All the extra "design" elements were carved away. To make it aesthetic (well, to some people anyway), the cap was designed. Plastic is much lighter than the alloy material.
    Yes, the Chief told myself, and then Tideland as well as many others.
    Doug Coleman
    Prius Product Manager
    Toyota Motor Sales, USA
    Kevin_Denver, Sporin and radiocycle like this.
  19. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    There's a saying in aviation...If it looks good it flies good. I guess the equivalent saying in the automotive world is...If it looks ugly, it's efficient.
  20. TeacherMan
    TeacherMan Junior Member
    33
    Gahanna, Ohio
    Boo,
    Just out of curiosity, has anyone here found a chrome or stainless steel trim ring that works with the 2010 alloy wheel? I think it would really dress the wheel up but nothing seems to be available.
    Tom
