What's with the Prius's hub caps?
Discussion in 'Gen 3 Prius Main Forum' started by Skoorbmax, Mar 28, 2010.
  1. karter
    karter Junior Member
    Whey you go to have the wheels balanced the center caps will need to come off to fit on the balance machine.
  2. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Re: Does anyone know about www.carwarrantyprotection.com?
    Why don't you look into the warranty offered on this site
  3. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I can get 3rd gen hubcaps off by pulling on two adjacent spokes. No use to pry the edge. Grap adjacent spokes and give a tug. They will come off and not break. Be nice if Toyota just gave a set of something like Insight wheels, in the Threes and Fours. Toyota needs to balance look of car and wheels. IMO, Insight 15" just right for its body. Prius on right, wheels 1" too small (Leaf has 16's and efficiency is paramount, why not Pri?)
  4. macmaster05
    macmaster05 Senor Member
    4,050
    730
    If you're a waffler and can't decide between wheel covers being on or off, there is one important thing for you to be aware of: Snapping your wheel covers on and off a lot will damage the lip of your rims. Basically you're scraping your rims with the wheel covers' attachment clips everytime you pull it out or pound it in. At least this was the case for my Touring rims. You can tell that the rims are a little chewed up along the edges where the clips for the wheel covers attach.
    Well, my wheel covers are off now, and I'm never going back.
  5. danvee
    danvee Blizzard Brigadier
    326
    53
    38
    New Jersey
    Not an issue on the 2010-11. The covers are all plastic with spring steel hoops that force the clips (which are molded as part of the cover) outward. The actual contacts are, in fact, plastic, so there's no damage to the wheel other than the possible abrasion of dirt within the wheel itself.
    That's probably why they're so easy to remove/lose/steal: no metal digging into the wheel.....
  6. macmaster05
    4,050
    730
    I know it's all plastic. My Touring rim covers are plastic too, but pull it on and off enough times and you'll see what I mean.
  7. danvee
    326
    53
    38
    New Jersey
    I knew that yours were plastic, but I thought that they had metal clips molded in....
    Caution, then, is warranted...:thumb:
  8. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    IMHO, the covers aren't for improved aero. Toyota engineers could have easily designed the alloy wheels for max aero and had them manufactured so. Wouldn't have added to the cost of manufacture and they wouldn't have needed covers. So, there has to be some other reason. FWIW.
  9. danvee
    326
    53
    38
    New Jersey
    Possibly to cover a wheel that was already used on another Toyota in a different (foreign?) market, and to give an "aero" appearance?
  10. erikl
    erikl New Member
    36
    SF Bay Area
    I have a 2010 prius II, and I can confirm that the hubcaps scratch the hell out of the rims. Plastic or no, they scratch and strip the rim clearcoat where they attach.
    I recommend ditching the hubcaps asap before you have the opportunity (e.g. a flat, etc.) to take them off, remount them, and subsequently scratch the rims. Either that, or protect the rims somehow, where the clips mount. Toyota you $#!@.
  11. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Management said "Make the lower model wheels uglier than the V wheels, so they added the wheel covers.:D
  12. briank
    briank Solar Powered
    51
    Massachusetts
    This has been touched on here but I think it is simply this:
    The stylists / designers came up with the look of the 15" 3rd Gen wheels. The executives loved them but the engineers said they would be too heavy (those would be thick spokes). So they made a light weight alloy rim and put plastic hub cabs in the shape they loved. Problem solved. A strong, lightweight wheel in the distinctive look they wanted.
    Obviously style is subjective though. Its nice we have a choice.
  13. macmaster05
    4,050
    730
    ^Heh. *clap* *clap* *clap*. Pretty clever there.
  14. GoldPianoGarden
    GoldPianoGarden Bling Meister
    841
    74
    98
    Brunswick, GA
    ah, bummer..... Well, hopefully I'll get a response from Tommy Kaira regarding the body kit. Due to the tsunami and earthquakes in Japan, getting responses from them has been RIDICULOUS. After I get the body kit and get it installed and painted, then that will help me see the "big picture" and get a visual for what wheel would look best with it....
  15. Advance The Man
    Advance The Man New Member
    49
    So can you simply take them off? Any photos without the hubcap?
  16. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Pics without the wheelcovers on? They pop right off. There are pic all over the site of peoples cars with them off but here are a few showing them on and off:
    If you take em' off you can fill in the hole in the middle as shown in the first pic with the center cap. There are threads about where to get them and for how much.
  17. Advance The Man
    49
    Wow. Seems to be obvious they look better without the wheel cover.
  18. eric0531
    eric0531 New Member
    23
    Mill Creek, WA
    It's all subjective, I like them better on.
  19. kneedraggin
    kneedraggin Junior Member
    I prefer them "on" myself...I had originally sprayed the alloys black but the appearance without the hubcap makes the rim look smaller so i also sprayed the hubcaps and am happier with the results.
  20. olyprius
    olyprius Member
    194
    31
    I'm going to keep my covers on for now. My wife is notorious for scratching up wheel covers. She scuffed the hell out of the oem wheel cover on our Toyota Sienna and almost bent the steel rim that was behind it. I was so pissed. :argue:
    I was thinking I could get away without the covers on our Prius. I had this idea that if she needed to drive the Prius, I would instinctively yell "WAIT ONE SEC!", run outside, and put the covers back on but that would get really old pretty quick and possible trigger another argument with her. :confused:
    I still miss our old Nissan Xterra with alloy wheels, the tires were so fat that there was no way a curb could touch it, but I don't miss how it guzzled expensive gas.
