What's your favorite "Prius noise"
Discussion in 'Gen 3 Prius Main Forum' started by Sterlingarcher6969, Jun 5, 2022.
  1. Sterlingarcher6969
    Sterlingarcher6969 Junior Member
    64
    22
    Bit of a weird on but I'm curious.
    We all know hybrids make all kinds of noises under normal operation compared to ICE only.
    What's your favorite of the bunch
    For me personally it's the brake booster when you open the driver's side door. It's like it's saying hello:D
    Second only to the high pitch whine going downhill around 70mph.
    52,776
    shhhhhhhhhhhhhhhhhhh............
    CR94 likes this.
  3. ChapmanF
    18,958
    The brakes quietly applying themselves just before the engine starts while parked, to reduce the rocking of the car. (Gen 3 does this. Gen 1 didn't. Not sure about Gen 2.)
  4. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    ??? Really? Mine doesn't do that, as far as I know, and it definitely "rocks," especially if parked on a slight downhill, with my foot not on the brake pedal. The reason this happens is clear if one knows about the planetary gearset in the transmission. Better it should rock than add needless wear to the fragile brake controller.
  5. bisco
    52,776
    who knew?
  6. ChapmanF
    18,958
    Well, you might think "better it should rock", but the folks programming the ECUs clearly thought "better it should apply the brakes".
    From here, I can't tell whether there's really something wrong with yours and it doesn't, or you just haven't recognized the sounds, but it's pretty unmistakable if you're listening for it. Sounds a lot like the brake self-test that happens a couple minutes after power off.
    And no, it doesn't eliminate the rocking completely. Just controls it some.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    The morning winter engine start up rattle
  8. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    If so, that has to mainly for aesthetic or marketing reasons, to avoid startling customers who don't understand the reason the car tends to "rock" when starting. .The parking pawl likely sees more stress due to other causes.
  9. Sterlingarcher6969
    64
    22
    Man I really wish the parking pawl wasn't so loose. I basically have to use the parking brake every time I get out or the whole car moves
  10. ChapmanF
    18,958
    Well, sure, it's to make the experience of the car nicer. I like that they think that down to such little things, so that's why it's my favorite noise.
    Also, I sometimes camp in my car, so I like that it keeps the rocking less pronounced.
    So to keep the thread on topic, do you like the clicky noise when you put the parking brake on?
    #10 ChapmanF, Jun 7, 2022
  11. Sterlingarcher6969
    64
    22
    I like the noise when I release it (kerchunk-THUD)
  12. ednorton
    ednorton Junior Member
    49
    delaware
    Actually the question should be " what's your least favorite noise" and my answer would be, " all of them" , they all scare the hell out of me!! :)
    bisco and Half Vast like this.
  13. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    The spaceship whirring sound when on regen braking.
    PaulDM likes this.
  14. Sterlingarcher6969
    64
    22
    That's a good one I like when you just barely are In the Regen zone so the hybrid system has to PWM the Regen so instead of weeeeeeeee it's a really fast wewewewewewe
  15. Yaesu
    Yaesu Member
    111
    34
    Kentucky
    I like the lack of sound when in EV mode.
  16. Canard
    Canard Member
    223
    Ontario, Canada
    Pretty specific, but at very low speeds, when you're in a drive through or have some other concrete/hard material wall just beside you that reflects the sound, you can really hear this lovely two-tone ____----- PWM-type noise as the motors move the vehicle forward (this is up-to about 5 km/h).
  17. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    558
    Tucson, AZ
    2021 Prius
    My favorite Gen II sound was the hot coolant storage cycle in the thermos bottle at turn-off. Getting ready to be less polluting for the next use period. Gen III is a little more difficult since it was so much more quiet. Maybe the brake pressurization cycle change in tone from before to after making the Prius ready. I could tell from the difference in low tone on 12V only to high tone when on DC-to-DC inverter power when it was time to put my 12V battery on the recharger/conditioner. Favorite Gen IV sound? It is also very quiet most of the time. I do like the Pedestrian Notification System sound and how people in parking lots and on street corners take notice of it. It allows me to proceed with no delays when people know I am there, as it is intended.
  18. nicoj36
    nicoj36 Active Member
    518
    162
  19. ChapmanF
    18,958
    Anybody with that as their favorite Prius noise probably likes having cavities drilled without lidocaine.
  20. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    I was unaware of that feature, so anything that makes the rocking less is good.
    I have no idea whether this is bad for the car, but when parking for camping sometimes I will let the car roll, quickly apply the parking brake which stops it, then immediately shift into park. It might be a placebo effect, but it seems like loading the parking brake like that reduces the shake/rock during the night when the engine starts.
