Wheel Alignment Question
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rebound, Apr 19, 2017.
  1. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    With 110,000 miles, maybe it's time for Prius to get an alignment. There are tons of tire shops that do alignment, and they all use one expensive machine or another. How do I figure out who has the best machine for aligning my Prius? And are there things I should make sure they do? Anything Prius-specific?
  2. Currahee
    Currahee Member
    103
    34
    CT
    Nothing Prius-specific but I've heard Hunter is the best machine, and probably the most common. Just make sure it's an actual lift and not one of those things they roll around to take measurements on the floor like some dealerships. Should include a test drive, again another thing I've seen dealerships neglect.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Are you seeing uneven tire wear or something indicating a need for an alignment (vibration, noise, etc)? How long have you had the current set of tires on your PIP?
    I got the second set of tires from Sears and every time I took out 2010 to them for the "free" tire rotation, they claimed I needed a $150 alignment. I asked what data they had to support their claim, as I saw no uneven wear. No good answer was given:confused:. Do I started rotating the tires and monitoring tread wear myself rather than wait over an hour and deal with their claims to help the tech supplement his boat payments
    That was at 55 k miles when I put on a set of Coopers and at 153 k miles now and have Bridgestone Turanza Serenities since 120 k miles. No signs of uneven tire wear in 100 k miles:).
    So if you are not seeing signs that you need an alignment, I would hold off.
    Rebound, tankyuong and Mendel Leisk like this.
  4. Mendel Leisk
    42,273
    If you're not noticing uneven wear, pulling or whatever, I would leave it be. I think the only thing easily adjustable is front toe. Rear camber will cause tread to wear faster on inside, to be expected.
    4th Gen maybe has more rear adjustment?
    Rebound and Raytheeagle like this.
  5. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,784
    Bay Area
    I don't believe you can adjust the Prius rear suspension since it's on a solid axle... The front you can probably adjust the camber and toe, if there's no camber, Toyota has a camber kit. I remember newer cars, the dealership just adjust the toe and let it go, unless there's obvious wear and tear on the tires and pulling on the steering wheel would we do more adjustments.
    Raytheeagle and Mendel Leisk like this.
