Wheel bearings going bad at 67K?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bac151, Feb 1, 2012.
  1. shaneb
    shaneb New Member
    Cairns Australia
    Gen 3 is easier to do than Gen 2. The Gen 3 hub falls apart after the 4 retaining bolts are removed. Remember to mark the backing plate position so you can refit it the correct way. Only use Genuine Toyota bearings the aftermarket ones are crap and do not last. At least you guys pay a good price for them A geniune bearing hub for a gen 3 cost $600.00 AUD here
    Meg&Bear and The Critic like this.
  2. swi66
    swi66 Member
    193
    Gasport, NY
    Is a front wheel bearing something covered under extended warranty?
    How about half shaft?
  3. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Covered under 5/60.
    MB860 ?
  4. jim240
    jim240 Junior Member
    24
    Can't you just buy a good quality Timkin or GMB bearing and press it on your self? I have done it a bunch of times on Mazdas and Hondas. That is how you have to change those. You can get just the bearing for 20 bucks on line.
    Member of the Wub Wub Club 122K
  5. yeldogt
    yeldogt Active Member
    810
    313
    NE
    having to replace the whole hub is common -- not just Toyota ....especially FWD.
    They don't normally fail -- maybe a problem with the design.
  6. jim240
    24
    Most FWD cars you just press the bearing out of the steering
    knuckel. Toyota and GM have a hub that bolts to the knuckel.
    The hub assembly is 300 bucks, if you don't have a press this is ideal.
    I think I'll try the bearing. Anyone have a worn out hub I can experiment with?
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Lost my front wb at 30K. Classic wup wup over 40. It was replaced under 3/30.
  8. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    Just checked with my father (which is a mechanic) and the left front wheel bearing needs to be replaced.
    Of course we are planning to replace it ourselve. Any tip for doing it? We already saw that we need a 32mm star box.
  9. Mr. Prius
    Mr. Prius Junior Member
    82
    24
    Need to replace the passenger side rear bearing along w both both rear rotors-should I do the driver's side rear bearing at the same time or just wait? I have a 2010 w 65k miles.
    iPhone ?
  10. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    If they aren't noisy just re-pack them.
  11. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    Same sound like the OP describes, front left wheel has a little play, only 40k miles, out of warranty :(
    Will investigate how much it will cost me, probably more than €300 only for the parts.
  12. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    I bought the SKF ones, feels solid and price was great from partmonkey.
  13. GasperG
    1,169
    601
    Slovenia
    2018 Prius
    Just got quoted 430 EUR from two different Toyota dealers, I also asked a generic shop and they said that non Toyota part does not exist and they were worried about replacing "you know regenerative braking", they could just said it in the first place that they don't want to bother with this car ...
    In the meantime I found the cheapest replacement on German ebay (I'm looking only in EU because of import duties and long shipment):
    TRISCAN Radlagersatz LEXUS (ZWA1_), TOYOTA (ZVW3_), u.a. ! | eBay
    It's from this company in Denmark:
    Frontpage
    What do you guys think? Go with it or get the Toyota part for 200 EUR more?
  14. GasperG
    1,169
    601
    Slovenia
    2018 Prius
    I ordered and installed the bearing from the previous link, the change it self was obviously very easy costing me only €30 at the local mechanic.
    The bearing it self is manufactured by Koyo just like the OEM part.
    Saved €230.
