Wheel bearings or tires? (humming)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mbtraveler, Jan 28, 2019.
  1. mbtraveler
    mbtraveler New Member
    Delaware
    I have 14 Prius 2 with 147K. Last week I started to hear a hum around 35mph and a little louder at higher speeds. This past weekend I replaced the rear driver side bearing since it seemed loudest from that corner. Took it for a ride and the noise is still there. Replaced the front driver side bearing and the noise is still there. I'm starting to think that maybe a belt let loose on one of the tires. Only because I originally thought it was the rear bearing and was wrong. I drive about 600 miles a week and now am not sure what is wrong.
    Thoughts?
  2. JC91006
    16,933
    8,643
    go get a free inspection
    NutzAboutBolts likes this.
  3. mbtraveler
    Delaware
    Where would you suggest I get a free inspection at?
    I thought someone else might have gone through what I am and had some helpful insight.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Swap the tire to a side that has no noise, if the noise travels with the tire then it’s the tire and hope it needs rebalancing with counter weights that’ll make the hum go away.
    Raytheeagle likes this.
  5. gliderman
    gliderman Active Member
    751
    225
    Go to where you bought your tires and ask them if they will rotate the tires and inspect the brakes and bearing while the tires are off. Most dealer will do that for free now to keep you coming back. If they find a problem go look at it before the tires are put back on.
  6. mbtraveler
    Delaware
    Thanks for the info. I rotate my tires every 5K when I change the oil. And I have looked at the passenger side but nothing out of the ordinary.
    I'll put the fronts on the back and see if the noise is greater in the back or the same. I guess at 147K, replacing the other 2 bearings isn't such a problem. The car runs excellent otherwise.
  7. ASRDogman
    ASRDogman Senior Member
    8,047
    4,078
    Sounds like that are a trick to find.
    Rotate the tired front to back. Start with drivers side. If the sound is still coming from the same place,
    rotate passenger side tires front to back. If the sound still there, maybe the right side bearings are bad.
    It is always best to replace bearings as a pair(front or rear).
    When you had them removed, or the wheels, and brakes off, did you rotate the bearing and listen for
    a bad bearing? You can feel what a new one feels like, then try the old ones.
  8. mbtraveler
    Delaware
    The rear driver side seemed pretty tight, since I already bought the new one, I thought it best just to replace it since I have 147K on it.
    The front driver side had some play in it and I was convinced this was the troublemaker. But it's still making a (hum) when driving. I guess it would be best just to replace the passenger side as well. Getting expensive though but I shouldn't complain, this is the first issue with this Prius.
  9. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Put wheels up in air and spin it
