Wheel Caps and Fuel Economy
Discussion in 'Prius v Fuel Economy' started by RP2016, Jan 3, 2015.
  1. RP2016
    RP2016 New Member
    Cleveland OH
    I just picked up a 2010 Prius and am noticing that the wheels do not have those plastic covers like my v does. Toyota tells me that my v has them for fuel economy. Does the standard Prius have them as well? I'm Not sure if the dealer removed them or not. Also, if fuel economy is affected does anyone think it would be worth the $50 on ebay to get another set? I like the wheels the way they are, but I will put caps on them if fuel economy is worsened much. Thank you
    Mike
    #1 RP2016, Jan 3, 2015
  2. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Yes, your car would have come with the plastic wheel covers.
    I put up with them for a couple of years but couldn't bring myself to put them back on when I pulled the winter tires and wheels last spring. I haven't noticed a significant drop in fuel mileage and feel much better about the appearance of the car.
    For owners of 2012 and later models, please understand that the 2010 - 2011 models have silver painted alloy wheels under the wheel covers.
    Do you have center caps on the wheels? I opted to install Toyota center caps to finish things off.
  3. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    #3 xliderider, Jan 3, 2015
  4. mikefocke
    4,073
    1,858
    Sanford, NC
    You may be getting confusing answers because your profile lists a v but you are speaking of a 2010, a year where there was no v wagon.
    I pulled the hubcaps off my '12 v wagon's wheels and installed ebay center caps. I have no scientific evidence that the mileage is affected. I doubt your dealer has any evidence either. The spoke wheels that were underneath the hubcaps have remained remarkably clean for silver colored wheels, little to no brake dust which confirms how little the Prius line uses the brakes.
    Your '10 car's previous owner may have pulled them off and they may be stuck in his garage like mine are.
    walldiver4 likes this.
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Proper wheel covers or rim designs do have an effect on fuel economy. It is miniscule, however. I doubt you will get $50 savings over their lifetime.
  6. RP2016
    RP2016 New Member
    Cleveland OH
    Thanks, that is answer I was hoping for. I already own a v wagon and just got the standard 10' last night. I tried to change it in my profile but it doesn't seem to allow for more than one at a time. Thanks for the help. Off to ebay to get those center caps.
  7. afob3
    afob3 Member
    124
    40
    TN
  8. mikefocke
    4,073
    1,858
    Sanford, NC
    You could add a signature line listing the details of both cars to make it clear you have two and what they are. That would post every time you post just as, for example, my fuelly numbers will post below this message. Only your signature lines would be in text.
