Wheel compatibility
Discussion in 'Gen 5 Prius Accessories and Modifications' started by rschlegel, Mar 30, 2023.
  1. bisco
    52,849
    that sounds like a great idea, i hope it works!
  2. Trollbait
    12,825
    Enough to pay for changing out the brake rotors and calipers? 16 inch is the smallest wheel that will fit with the OEM brakes. The wider tire of the Camry will counter some of the benefits from the weight reduction.
    52,849
  4. Billy56
    Billy56 Member
    83
    83
    Seattle, WA
    2020 Prius
    L Eco
    Maybe the best way to compare the tire to speedometer estimate, is to find the tire specs for "revolutions per mile"...
  5. drash
    drash Senior Member
    2,600
    1,339
    Upstate NY
    XLE AWD-e
    You're accusing @bisco of needing bigger brakes? Surely you jest.
    bisco and Trollbait like this.
  6. rschlegel
    rschlegel Junior Member
    Raleigh, NC
  7. rschlegel
    Raleigh, NC
    I heard someone on Youtube who reviewed the Prime XSE state that the SXE has 12" brake linings. If so, would I need to change my brake linings to accommodate a smaller wheel size?
  8. Hammersmith
    Hammersmith Senior Member
    2,484
    2,543
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I think that would be a very bad idea. Beyond just voiding your warranty, I'd hate to even start to try and figure out which rotor/caliper/pad combination would work and give you comparable stopping ability to stock. And if all you're trying to do is get better fuel economy, you'd probably spend more on new components than you'd ever save in fuel.
  9. rschlegel
    Raleigh, NC
    Looking at the specs I see that each trim level has the same brakes: Power-assisted ventilated 12-in. front disc brakes; solid 11-in. rear disc brakes with Electronically Controlled Braking (ECB) system, and Star Safety System.
    This should make it safe to replace the 19" wheels with 17" wheels.
    #29 rschlegel, May 7, 2023
    dbat23 likes this.
  10. rpT
    rpT Member
    45
    38
    new york
    2023 Prius
    Limited AWD-e
    Kumho Temporary Spare T145/90D16 106M 5008233
    will this fit my Prius 2023 19” limited awd as a spare?
  11. Hammersmith
    2,484
    2,543
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    That's the correct size. Of course you also need the wheel, but you probably already know that.
    My wheel got here yesterday and my tire should get here soon. I went with a Yokohama for no particular reason.
  12. rpT
    rpT Member
    45
    38
    new york
    2023 Prius
    Limited AWD-e
    Haha! You give me too much credit. Please let me know what wheel you got?
  13. Hammersmith
    2,484
    2,543
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    It's Toyota/Lexus part number: 42611-21280. Beyond the 2023 Prius, it was also a spare wheel on the C-HR and the Lexus UX 200/250/h series. MSRP is $102.13, but you should be able to find it for under $70 if you shop around for the dealership/outlet with the best price. You could even try a junk yard/ebay for a complete used wheel+tire, but I don't know how many are floating around out there(if any).
    If you want create your own OEM install, you're going to need at least four other parts, of which at least three are not available in the US yet. There are two white floor boxes that replace the ones already in the car. We haven't locked down the part numbers for those yet, but figure the price for both will be around $200 after discounts. There's also a hold-down bolt that will be around $15. I found the part number for that, but none are available yet. Finally, there's a tool kit that will set inside the spare wheel. This is important for an OEM install because it fills in the center of the wheel to support the deck lid. I haven't tracked down the part number, price, or availability for that yet(low priority for me since the boxes and hold-down aren't available yet).
    All together, a complete OEM conversion should be under $500 using all new parts.
    $200 - floor boxes
    $100 - tire
    $70 - wheel
    $15 - hold-down
    $50? - tool kit
    BDR529 likes this.
  14. CruisnGrrl
    CruisnGrrl Active Member
    150
    128
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    I started looking at prices on steel rims for my Prius Prime XSE Premium.... even though it comes with 19" wheels there is more than enough room for switching to 17" rims. What made my jaw drop was the cost of 17" steel wheels. Our van takes 16" rims.
  15. phase
    phase Member
    106
    42
    Portland
    2023 Prius
    LE AWD-e
    Has anyone figured out the absolute smallest wheels that will fit the 2023 Prius?
  16. CruisnGrrl
    150
    128
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    I believe some 16" rims will fit. your mileage may vary.
  17. tmorrowus
    tmorrowus Member
    514
    I was hoping the spare from my 2004 gen2 Prius would fit on my 2023 gen5 Prius Prime SE, but looking at the bolt pattern the gen2 spare has smaller bolt spacing. And the info at the beginning of this thread confirms. :eek:
  18. PandaBOT
    PandaBOT New Member
    Colorado
    2023 Prius
    XLE AWD-e
    Has anyone here tried the stock 195/60R17 tires on the 2023 AWD XLE? I just blew a tire today and the wait time for the 19" tires is about 30 days! I asked the dealership about doing this switch, but they don't have any experience with the new Prius and don't know if it'll clear the brake calipers.
  19. Mendel Leisk
    42,343
    Brakes are almost certainly the same, regardless if it comes with 19” or 17” rims.
    PandaBOT likes this.
  20. otatrant
    otatrant Active Member
    349
    212
    San Francisco
    2023 Prius Prime
    XSE Premium
    I have 205/55R17 cross climate tires on 17x7.5+45 wheels on my Prius Prime. Their hasn't been any issue changing the wheels and tires.
    Tirerack has 195/50R19 Michelin X-Ice Snow tires in stock. That would keep you from having to change your wheels.
