Wheel Fitment for '08 Base Model
Discussion in 'Gen 2 Prius Accessories & Modifications' started by jonah.borgenicht, Sep 29, 2017.
  1. jonah.borgenicht
    jonah.borgenicht Junior Member
    Salt Lake City
    I've got a quick question about some wheels that I found, They're JNC 014s in Gloss Bronze (sorry I can't post a link yet since I'm fairly new).
    I'm thinking 17x8.25s all around.
    I'm just wondering if these would fit on my '08 Prius, and what tire size I would need.
    If they don't fit I would love to know of some other similar options I could go for, or what steps I could take to make them fit.
    Thanks
  2. Kevin_Denver
    Kevin_Denver Active Member
    581
    421
    Denver, CO
    If you use 205/45R17 or 215/45R17 they should work so long as you get a rim size with the correct offset. Do some searching on PC for offsets for 17" rims; I know there's a good thread or two on the forums with people posting what offsets they've used (just do not use the 3rd gen Prius as a reference; it has a larger wheel well). Also, expect a 5 or more mpg reduction in your fuel economy.
  3. jonah.borgenicht
    Salt Lake City
    Thanks so much man, I really appreciate it!
  4. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    744
    Delaware
    my wheels are 40mm offset. I believe 50mm would fit better and you might be able to squeeze a 225 tire in there without rubbing or modding the fenders. I don't think more than a 7.5" wide wheel is a good idea though.
  5. jonah.borgenicht
    Salt Lake City
    Yeah I kind of agree, I was thinking 8.25 would be a little too wide.
  6. 69shovlhed
    2,170
    744
    Delaware
    I got 7" wide, and the wheels came with 225/50r16 tires; they poked out in the front enough I knew they would munch my fenders. however there was plenty of room on the inside.
  7. jonah.borgenicht
    Salt Lake City
    Good to know what I need to look out for.
  8. Speedfink
    Speedfink Certified Bad@$$
    26
    SoCal
    Four Touring
    16x7 @ 45mm offset on my touring, test fit 17x7.5 at same offset and it appears good, although I haven't taken the plunge and done it so I couldnt tell you if it scrubs in the front. The 17x7.5 test fit at 45mm offset was with 205/45 R17 Yokohamas.
