Wheel Inertia explained.
Discussion in 'Gen 3 Prius Technical Discussion' started by SpaceShip1, Jun 12, 2016.
  1. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    Regarding air drag, you are substantially correct.
    Regarding rolling resistance, you are still confused. "Contact friction" is not the same as rolling resistance. Even if (hypothetically) a wide tire and a narrow tire were made of identical materials and had the same friction coefficient against pavement, on the wider tire, a larger area of tread rubber must flex from round to flat (at the bottom) and back to round with every revolution. Flexing rubber absorbs energy through mechanical hysteresis. That's not the only reason the wider tire is likely to have higher rolling resistance, but might be the most obvious.
  2. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Or is that Will Bobson? :D
    52,862
    will do!(y)
  4. SpaceShip1
    SpaceShip1 New Member
    Santa Barbara, CA
    Yeah contact and rolling have nothing to do with each other, not sure why I said that...
    But I still respectfully disagree with you. The rolling resistance of a tire is based on the amount the tire deforms in the radial direction, and if a wide tire and a narrow tire are at the same pressure, the narrow tire will deform more in the radial direction. A tire that deforms more in the radial direction will be less round, and therefore have a higher rolling resistance. See this article: Rolling Resistance | Schwalbe North America
    And also, wider tires are typically run at a higher pressure.
  5. Toppcat
    Toppcat Member
    223
    69
    Northern California
    Very true! But the more weight will carry more rotational inertia! But requires more energy to turn over! I observed my Prius w 17 inch will over take Prius w 15 inch wheel on a down hill.
