Wheel noise, 230k, tried balancing, tires look good
Discussion in 'Gen 3 Prius Main Forum' started by georgefrank, Dec 2, 2023.
  1. ASRDogman
    ASRDogman Senior Member
    7,597
    3,916
    WHAT??? NO, then yes????
    Im thinking not to touch it at all, the nightmare I just went through, I am nervous about doing anything to the car, but
    I will be putting in new front struts and front bearings the next chance I get
    Wiper assembly is easy, 15 minutes maybe?
    ...tons of stuff to come off, including the window-shield wiper system
    Press? Nothing to press...
    And to change those front bearings, they say you dont press, yes you do
    No, you don't. You don't even need to remove the axel, just the nut.
    Only the caliper because it's easier to get to the bolts.
    Spray rust penatrent on the hub before starting the job.
    After loosening & removing the bolts, tak a large hammer and punch and smack
    the hub on the side so it rotates clockwise, the again counter clock wise,
    Spray with more rust penatrent, and repeat until it turn to cover the bolt holes.
    Then install a shorter bolt in opposite corners and snug up the bolts, then smack
    the hub, tighten the bolts, and repeat until the hub comes out.
    A little slow, but effective. If needed, you can take a chisel and work it in behind
    the hub. Smacking it to rotate it back and for and working the chisel will work the hub out.
    After it's out, use a wire brush to clean eveything up. Put some antisieze on the matting
    surfaces before intalling.
    I have to completely remove the knuckle, press out the factory bearing
  2. georgefrank
    georgefrank Junior Member
    83
    earth
    wow interesting... I'm curious to see how far off the speedometer is with the 205/50/17, I'll test it out using some kind of gps speed tracking
    I'll go 70 mph on the gps tracker, then see what the speedometer says
    These details have not mattered yet in city driving, the way the roads are nowadays, I am willing to sacrifice those a bit for the big advantage of having a bit more clearance
    There have been times where I was going over a speed bump, and it would bottom out on the frame
    Cornering: I am not noticing any difference yet
    yes I definitely learned my lesson, never put pressure on the calipers when they are off the rotor
  3. georgefrank
    83
    earth
    What I mean exactly: I am not touching that car and taking everything apart if I will need it the next day, meaning
    the next time I do surgery, I have to finish up everything (the bearings and the struts)
    I understand that this task might not seem that big, but ALL of the tasks, having the energy and time to take everything apart and put it back together in time for when you need the car again, and not make the mistake I did before:
    All of that requires tons of planning, I have to do surgery laying on carpets/dirt, I have drag the jack and blocks in the dirt and get the car up, etc, get all the tools there, setup a table, setup a place to put all the parts
    I dont have a shop with a hard ground, or access to one
    Yes, I will explain what happened last time I was doing surgery:
    Yes, I took the big nut off the axle, then watched how youtube video took it off, tried to emulate it, got pretty frustrated, tried using chisel, tried everything, even hit my right index finger, its still slightly purple, you can see in the video, but it was swollen for a week
    I must've spent 2 hours watching videos, trying to separate the parts, nope, hammered, chiseled, I even tried heat gun for 10-15 minutes, frustration and fatigue lead me to hit my finger, I hit it so hard I had to sit down for 30 minutes
    Another annoying detail: I bent the brake shield, so after I put it together, now I am hearing a grinding sound for many days until I was able to get back under it, it was hitting the rotor a bit
    My theory: that bearing has been through 11 years of hot/cold cycles that it is somewhat seized
    Even in the youtube I watched, the guy had to do the same thing, he couldn't get it off with heat/oil/chisel/whatever, then he ended up taking the knuckle out completely with the bearing attached to it
    He had a shop press (big harbor freight one), and he had to use that to get the bearing off the knuckle, (I do not have a press machine)
    Earlier that day: i successfully changed out the rear bearings without press
    Wow, ok, I am listening
    I'll be saving these statements for when I am in there doing surgery
    At this point: the car is magic, it glides on the road, no noise, and the clearance is fine, meaning:
    I might wait to do this surgery procedure once I have a better environment to work on it (I am also working on that any chance I get)
    Those front struts after the beating the road has put on them, are clapped out and all the protective plastic on the shock is torn, meaning:
    yes, I do want to replace them, but I want to plan to replace everything at once, and not be in a hurry like last time and cause a problem
    On a dry hot day, those shocks will creak, no creaking when humidity in the air
    #83 georgefrank, Dec 23, 2023
  4. georgefrank
    83
    earth
    205/50R17 tires have a diameter of 25.1" (638 mm), a tread width of 8.1" (205 mm), and a wheel diameter of 17" (431.8 mm). The sidewall of the tire is 4.1" (103 mm), and the tire's circumference is 78.8" (2003.3 mm).Aug 9, 2022
    Outer diameter 195 65 15: 24.98 inches
    Basically: the 205 50 17 is about .1 inches higher
    Why does it feel 1-2 inches higher?
    Heres the data on the 215 45 17:
    215/45R17 tires have a diameter of 24.6" (626 mm), a tread width of 8.5" (215 mm), and a wheel diameter of 17" (431.8 mm). The sidewall of the tire is 3.8" (97 mm), and the tire's circumference is 77.2" (1965.6 mm).
    wow: the factory 17s are 0.4 inches lower than the 15 inch factory wheels, (25 inches minus 24.6 inches)
    #84 georgefrank, Dec 23, 2023
  5. Mendel Leisk
    41,466
    Those are diameters. The car will be lower by the difference between the radii.
