Wheel/Rim Selection - Uncertain which to buy. Do I go with smaller wheel width, or smaller offset?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by AmPriusPrime, Jul 21, 2023.
  1. AmPriusPrime
    AmPriusPrime New Member
    US
    2018 Prius Prime
    My 2018 Prius Prime with Premium Pkg has:
    OE Rim Size and Bolt Pattern
    15×6.5 5×100 ET40 54.1mm CB
    OE Tires:
    195/65R15
    I just got 4 new all-season tires, same size, and kept the 2 rear tires that had less wear and were still good.
    My idea is that if I get a new wheel, as opposed to a donut, and put the better of the two tires on it, then I'd have an extra wheel to keep strapped in the back as a spare on my upcoming trip.
    In a few weeks, I'm going to be driving from the US East coast to the North West, down the West coast, then back East, putting around ~6500 miles on my car in a month's span. Just got the new tires put on, and plan to get them rotated once I get back. I also have a scheduled oil change, and state inspection at the dealership next week. Hoping if I get a wheel by then, I can have them put the tire on it so it's ready as a spare.
    With the wheel, it's been frustrating in my searches online to find the exact match of a wheel sized 15×6.5 5×100 ET40 54.1mm CB aftermarket. The dealership quoted ~$400 for an official match, and I'd like to find a more affordable option.
    The closest I've come to finding is:
    15×6 5×100 ET40 54.1mm CB
    15×6.5 5×100 ET38 73.1mm CB
    I'm between the two options and not sure which is better and will have the most minimal impact on mileage or reliability in the event I need to use the spare. Are either wheel option within the allowable range and would be fine, and also with using the OE 195/65R15 tire size I have?
    Either I go with a wheel that has a 6" wheel width against OE 6.5" width, which the other 3 will be if I ever needed to use this spare, or the other option of a wheel with a center/hub bore of 73.1mm, and if I get Hub Centric Rings 73.1 to 54.1 that should resolve, but still has an offset of 38mm vs OE 40mm offset that the other 3 would have.
    Is a wheel with 0.5" less wheel width or a wheel with 2mm less offset the better choice for a spare, and could it be used more longterm than that potentially since it's so minimal?
  2. Mendel Leisk
    38,657
    In 2010 I got these for snow tires, $70 CDN apiece, through dealership (with snow tires installed):
    Corolla steel rim, part no: 42611-02471 (2003-2008 corolla or matrix, CE, LS, S)
