Wheel selection help
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Acidbass32, Feb 16, 2017.
Tags:
  1. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Alright guys the time has come where I am seriously looking into new wheels and tires. I have been looking at these for awhile
    Enkei Tuning TD5 Pearl Black
    But I wanted to see if there were any suggestions so the speedo isn't totally off. I want to have a wider tire so and a slightly larger rim than the stock 15x6. I live in south Texas so crap roads are not uncommon and I don't want to bend and screw the rims over.
  2. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    Nice looking wheels. Odd the Enkei doesn't show the weight specs on these wheels.
    I assume your good with lower mpg? Got any emulator pictures with the wheels on a Prius?
    When I ran 17x7 with 215/45/R17 there was enough rubber to help cushion the rough roads of Alberta. But even here in Dallas with the ground constantly shifting the roads seams and no pot holes - smaller profile tires are bother - currently on my 19x7.5 215/35/R19
  3. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Well technically the wheels are meant for a FR-S, I just like the larger offset and the wider wheel. I'm already getting lower MPG because of all the crap I have mounted to the roof and modded suspension so that is not a concern. I figured I could go with FR-S wheels because they are the same bolt pattern as the prius and relatively the same size. Eventually I want to flare the fenders and have a pseudo widebody look but for now just wheels and tires that are flush with the wheel well.
  4. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Justdidit likes this.
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    I like those TM7!!
  6. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    I really do as well, a little more expensive but I think they will give me the look I am looking for without the use of spacers and hopefully no rubbing
  7. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    What tire size you gonna run? I've found that 215 on a 45 offset wheel is the most you can run without rubbing - especially if lowered.
  8. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Well I need to adjust the ride height on my coilovers when I have a break from school for sure. I was going to run the 215/45zr17 pirelli Zero Nero tires. I think that should give me enough sidewall to not feel every little bump in the roads and not look like its rolling on rubber bands.
  9. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    215 on a 17x8 might be ok since it only comes in a 45 offset. 17x9 might be a stretch. I'm guessing if lowered, you'll need to roll the fenders a bit.
  10. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Yeah I really only want to go to 8", 9" is too much for a Prius. I'll save the super wide tires for my RWD vehicles lol
  11. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    744
    Delaware
    I got 40mm offset 16x7 motegi's, with 215/55r16. if I hit a big dip they rub just a tiny bit. it looks like there is plenty more room inside for larger offset.
  12. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Any pictures?
  13. 69shovlhed
    2,170
    744
    Delaware
  14. 69shovlhed
    2,170
    744
    Delaware
    these are with the 225/50's that came on the wheels. you can see the poke would have caused some serious damage without surgery on the fenders. prius20150623_210228.jpg prius20150623_213120.jpg
  15. 69shovlhed
    2,170
    744
    Delaware
  16. 69shovlhed
    2,170
    744
    Delaware
    sure wish I could have used those 225's. would have killed the mileage, but the ecopias I bought don't have much more traction than the junk integritys that came on the car.
  17. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    I really like the wider tire makes the car look better in my opinion. Hmmm more ideas to consider, I have pirellis on currently, but ever since i found out the FR-S has basically the same wheel set up as a prius, My options are through the roof tire and wheel wise.
  18. 69shovlhed
    2,170
    744
    Delaware
    yes wider always looks better, but if the tires are tearing up the fenders, killing mpg and/or acceleration, at a certain point its just too much. I'm thinkin 17 x 7.5 with a deep backspacing and 225/45 or 40 is about as big as you can go without fender surgery or damage.
  19. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Eventually I'll flare the fenders for a faux wide body look but not anytime soon.
  20. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    So there has been a new development in this dilemma of wheel selection. I realized that everyone does black or brushed wheels and I want my car to stand out even more.... So I am actually thinking about getting colored wheels or a set I really like and getting them powdercoated. Probably the TM7's
