Wheel swap
Discussion in 'Gen 4 Prius Technical Discussion' started by clash01, Feb 1, 2020.
  1. clash01
    clash01 Junior Member
    Can I swap my 2010 model 5 17’s to my 2017 model 4 that has 15’s?
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    As long as the lug pattern is the same yeah.
  3. krmcg
    2,592
    2,393
    Whittier, CA
    yes
  4. Mendel Leisk
    42,343
    Going the other way from stock 15" to 17" is also physically possible, but there might be some variations in suspension/steering and who knows what: the 17" stock vehicles may have some beefing up? On 3rd gen at least, the turning radius was greater on the 17" (lotsa fun trying to get into a tight parking space), the steering turn lock-to-lock is different, maybe some suspension tweaks too?
    That said, lots of owners do that as well, seem ok, lol.
  5. Prodigyplace
    12,712
    11,848
    Central Virginia
    Read the first post again. That is not the other way. They want to put 17” on a 15” Gen 4.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Did someone say recently that the 17" Gen 4s have a different steering ratio, and different Power Steering settings from those with 15"? Maybe a GOOGLE search might find it?
    I just found this (re 2016 cars)
    Rough Road Area Spec cars have different steering ratio (13.2 vs 13.4).
    And depending on model, there is a difference in steering ratio.
    The Turning Diameter is different too - but then, it could be just the tyre width causing that.
    Prodigyplace likes this.
  7. Mendel Leisk
    42,343
    Oh woops. Yeah, so what I was saying about going 15" to 17" applies: it's physically possible, and very likely fine. Still, Toyota may have tweaked the suspension/steering for the stock 17" models, which kinda begs the question: are the tweaks (if they still exist) trivial, or more important.
    Droves have done the 15" to 17" switch, survived.
  8. alanclarkeau
    7,045
    7,593
    refer my post above (#6) for steering ratio.
    Prodigyplace and Mendel Leisk like this.
  9. Mendel Leisk
    42,343
    No. Our 2010 Touring turns like the Queen Mary, with both the 17" OEM and the 15" snow tires. Try as I might, I always end up slightly diagonal in perpendicular parking spots.
  10. Prodigyplace
    12,712
    11,848
    Central Virginia
    I believe the overall wheels have the same outside diameter with just different sidewalk heights. That would give the 17” a harsher ride.
  11. Prodigyplace
    12,712
    11,848
    Central Virginia
    As a Canadian I understand what you mean. Please put it in simple terms for the US folk here.
  12. Mendel Leisk
    42,343
    Turns like Battlestar Galactica?
    alanclarkeau and Prodigyplace like this.
  13. Prodigyplace
    12,712
    11,848
    Central Virginia
  14. alanclarkeau
    7,045
    7,593
