Wheel Weight Resources
Discussion in 'Gen 2 Prius Fuel Economy' started by sidecar, Apr 27, 2011.
  1. sidecar
    sidecar Member
    342
    44
    Australia
  2. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Thanks, sidecar!
    I noticed they list my wheel (Centerline RPM) at 13.5lbs which seems a bit on the light side. I weighed mine with the Kumho ecsta ASX (22lbs) and they came in at approx. 37.6lbs-38.2lbs on a high quality nitrous oxide scale. I deducted the tire weight and came up with a wheel weight of 15lbs.. This is also what Centerline says they should weight. I'll weight them again next time I purchase tires for them. :)
    My original post on the wheel weight. http://priuschat.com/forums/gen-ii-...g-back-stock-rims-testing-mpg-difference.html
  3. sidecar
    sidecar Member
    342
    44
    Australia
    yes I noticed that while browsing the numbers
    but are you sure about that F8L; 13.5lbs is awfully light
    might be worth me querying them about their source
    Looks like it could be possible to have lighter wheel equipment for stock fitted 15" cars. Perhaps a potential saving there noting the following
  4. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Yeah, that's what I mean. 13.5lbs seems too light for the 17x7" RPMs. Even Centerline says they weigh 15lbs.
    It may be worth emailing them for their sources. :) Either way, thank you for posting the information.
  5. sidecar
    sidecar Member
    342
    44
    Australia
  6. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    2x is absolute worst case. The get 2x -all- the additional weight would have to be located at the outer surface of the tire tread.
  7. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
  8. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    That is the same thing that sidecar posted originally. They use the same weights which is totally off for my wheel. My wheel, Centerline RPM, weighs 15lbs. Not 13lbs.
  9. stefano5777
    stefano5777 Member
    380
    47
    Relax F8L Ill pull link :) will that make you happy!
  10. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    I'm not upset. :)
