Wheels and Steering and Shocks, Oh My!
Discussion in 'Gen 3 Prius Main Forum' started by Prius Team, Mar 31, 2009.
  1. jprates
    jprates https://ecomove.pt
    387
    42
    Moita, Portugal
    2017 Prius PHV
    Yes, I was assuming on both examples that the maximum angle done by drive wheels was the same.
    If two given cars have the same maximum angle at the wheels, then the one with the more direct drive ratio will have the smaller lock-to-lock turns.
  2. Tideland Prius
    16,677
    gotcha. Thanks!
  3. accordingly
    accordingly Member
    268
    63
    Madison, WI
    You're right about the amount the wheels turn being important in the equation. But for the most part, the differences between the amount the wheels can turn is insignificant to the differences in steering ratios, so a car with a lower ratio almost always has a lower lock-to-lock as far as personal production vehicles go.
    In the 2010 Prius, and simplifying slightly, the Prius models 1-4 can turn the tires 74.8 degrees total from one extreme to the other. The Prius 5 can turn 69.3 degrees. That means you get a couple more degrees of turn at maximum on each side with the Prius 1-4, but again this simplifies things like the fact that the wheels do not turn in parallel and have camber and whatnot.
    The formula is (steering wheel lock-to-lock) * 360 / steering ratio. Previous posts have the numbers.
    The Prius V has faster steering, meaning it has a lower ratio (14.6 in the V and 17.6 in the rest) and in real world terms this means you have to turn the steering wheel less to move the tires a given angle. In the Prius 1-4 you're turning the steering wheel more to get the same effect, though you can get a slightly bigger maximum turn angle, taking more turns of the wheel in the process of course.
  4. Tideland Prius
    16,677
    awesome, thanks guys!!
  5. accordingly
    accordingly Member
    268
    63
    Madison, WI
    Surprisingly, the 17" tires have a slightly smaller outside diameter than the 15" tires.
    The 17" tires are 215/45R17 - which comes out to 24.62 inches
    The 15" tires are 195/65R15 - which comes out to 24.98 inches
    Formula is width X aspect ratio X 2 + wheel diameter = total diameter
    Width is the first number (in mm), aspect ratio is the second before the R, and the last number is the wheel diameter in inches.
    The 17" tires are .79 inches (20mm) wider however, which is the reason they cannot turn as far without rubbing.
    There is actually one 195/45R17 tire made by Yokohama (on TireRack at least), but it is a summer tire. You could swap out your 15" wheels for 17" quite easily with this tire and not worry about the rub.
  6. jprates
    387
    42
    Moita, Portugal
    2017 Prius PHV
  7. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    One more thing to add - 2004 steering was 19.1:1 per NCF, so I suppose the 2010 is "better" either way.
  8. Tideland Prius
    16,677
    So technically, regardless of model, the 2010 has a quicker steering ratio?
    How would that explain the extra turns (¼-½)?? Perhaps it's a placebo effect?
  9. HTMLSpinnr
    5,341
    920
    251
    It's possible that my "standard rate turn" (sorry, pilot term) now requires just 1/2 rotation whereas before it required more. There's just something awkward about that exact spot tho that takes some getting used to.
    Lemme go take each car around the block to confirm.
  10. jprates
    387
    42
    Moita, Portugal
    2017 Prius PHV
    See if it has something to do with driving wheel size. Probably you're not yet "at home" with the larger wheel? :cool:
  11. HTMLSpinnr
    5,341
    920
    251
    That's slightly possible, but steering wheel diameter shouldn't have anything to do with # of rotations.
    Going around a particular corner on the right side of the road took ~3/4 turn in the 2004. In the 2010, it took nearly 1 full turn. Last corner took about the same in both cars, but it was hard to judge whether I was in the same position on the road both times.
  12. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    ummm...didnt engineer mention a slightly greater turning radius? that would explain it. less angle for tires to travel would explain less steering wheel angle
  13. jprates
    387
    42
    Moita, Portugal
    2017 Prius PHV
    I know LoL, I was referring to the placebo effect, to your "feel" ;)
  14. exbauer
    exbauer Active Member
    1,188
    102
    Washington
    I didn't read through all the pages. But, I picked up my V ATP last night and this morning took it too work. With the gen II I was able to do a u turn with out having to do a 3 point turn. But, with the gen III I had to. I was a bit dissapointed.
  15. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    gen 3 is reported to have bigger turning radius... at least pretty sure it was mentioned. was thinking about going thru all the videos, but no time for that...tuesday is pretty much errand day
  16. accordingly
    accordingly Member
    268
    63
    Madison, WI
    That's correct.
    2009 has a curb-to-curb radius of 34.1 feet.
    2010 has a curb-to-curb radius of 36.8 feet (39.2 feet in the 17" wheel model).
  17. Tideland Prius
    16,677
    10mm extra width in the tyres add to nearly 3 ft extra? There must be something in the wheel well that has changed too allowing less turn on the 2010 with 15" alloys.
    Sucks. The thing I loved most about the Gen II was the ability to u-turn (and the same for Gen I owners who had an even tighter turning circle)
  18. accordingly
    accordingly Member
    268
    63
    Madison, WI
    FINALLY!!! From the is 2010 not ready for prime time thread:
    I think I'd pass on the upgrade as the assist is already too great for me. I don't think it's the damping that's the issue, when enthusiasts and reviewers talk about road feel they don't mean the wobble feedback of the uneven road that dampeners suppress- it's the feeling of your hands directly controlling the tires and feeling the torque response on a turn. High ratio and high assist are pretty much the opposite of a responsive steering system. But I guess I'd have to drive it to feel. In reality I don't think I'll be able to really notice anyhow, but I guess now it looks like having the option may be better.
    I wonder when they will begin to offer steer by wire, as it will get rid of the wasteful continuously running power steering motor and increase MPGs. Seems like a natural for the Prius, especially considering road feel is not one of the strong suits anyhow.
  19. HTMLSpinnr
    5,341
    920
    251
    Actually the 2010 Steering system doesn't continuously run the motor.
    NCF Guide quote:
  20. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    Doug may not have described the tweaks correctly. I agree that it seems that reducing the boost would be better but Toyota has to be aware that the "numb" steering is the most criticized feature of the 2010. Hopefully the engineers/programmers will be able to make it a little less numb somehow.
    They did say that they would get back to us on how an upgrade would work. You may be right that buying soon and having the option to upgrade is the way to go.
    Roy
