Wheels fitment
Discussion in 'Prius c Accessories and Modifications' started by loklok1, Sep 5, 2012.
  1. loklok1
    loklok1 Junior Member
    44
    I'm wondering if anyone know if 17x7.5 +45 wheels would fit on a Prius C?
  2. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
    Maybe. Stock wheels are 15x5 et40, so your proposed wheel ends up putting about 1.4" more width inboard. There may not be enough strut clearance with that big a change. I've test-fit a 7" wide et37 and there was strut clearance, however I didn't measure how much beyond "a finger width".
    I'm sure you already know about the negatives of significantly increasing your unsprung mass, changing scrub radius, and all that jazz.
  3. loklok1
    44
    thanks for your reply Ryephile
  4. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    I am curious if a 17 inch wheel might work too. I bought 15x7 40 wheels and they are fine. I have the stock 175x65 Goodyears on these wheels. If I can wear them out I plan to put a much larger tire on this wheel.
    Dan
  5. Ryephile
    418
    151
    24
    Metro Detroit
    Good to know 7" wide et40 fit fine.
    FYI, the wheel diameter you choose isn't terribly relevant, assuming they clear the suspension/brakes, and you can find a tire size that is rational [i.e. about 24" diameter]. As such, you can rock an 18" wheel with 215/35-18 if you please. What dictates the fitment [strut clearance and fender flushness] is mostly a function of wheel width and offset.
    Let's just make it easy:
    Any wheel diameter + 7" width + between 37 and 40mm positive offset +205 wide tire or less = success.
    Examples:
    205/55-15 on a 15x7 et40 = excellent
    205/50-16 on a 16x7 et40 = excellent
    205/45-17 on a 17x7 et40 = excellent
    Don't want to totally kill your fuel economy? Get a narrower tire.
    185/60-15 ,195/60-15, 185/55-16, 195/50-16, and 195/45-17 will all work.
    Want to own it at the Autocross?
    215/45-16, 215/40-17, 215/35-18 will work great but may run into rubbing when lowered.
