Wheels? Stock? Fancy alloys?
Discussion in 'Gen 3 Prius Main Forum' started by Ianmeister, Jan 1, 2021.
  1. Ianmeister
    Ianmeister Active Member
    316
    320
    Meridian Idaho
    So my new to me gen3 package II has these allow wheels. Anyone know the scoop? Will they affect mileage over stock with the plastic zippy aerodynamic wheel covers? What day you? 36D4EDC2-D634-48EB-B878-D043291D7067.jpeg
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Those are the stock wheels under the plastic wheel covers.
  3. Mendel Leisk
    42,354
    From 2012 on Toyota uglied them up even more, went from silver to black.
    If you stick with those putting centre caps on will make them look more complete, and hide the rusty hubs. You can get knock offs on eBay, may fit perfect, mine needed a bit of dremel tweaking.
    I picked up a set of PIP 15” rims, which look much more civilized imho. Have yet to use them though; will likely mount new snow tires on them next fall, a step up from black steel rims. Missus likes the OEM 17’s so I can’t sub them for the all seasons.
    #3 Mendel Leisk, Jan 1, 2021
  4. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    From the the road rash on your wheel, The previous owner probably trashed the nasty hubcaps. I picked up center caps from eBay for 10$ . fit great, just tapped them in! polish them up and they look much better then the plastic hubcaps.
  5. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    As far as the Mileage difference, I have a 2010 with 80K. Driven under 5 mi. per trip and average 45-50 mpg in the summer and 40-45 in the winter. No lrr tires and I drive it like a normal car. No hyper mileling here!
  6. Mendel Leisk
    42,354
    For the curb rash:
    fill in and sand the gouges, clean well, then go over the distressed zones with a Toyota touch up pen, colour Classic Silver Metallic (1F7), it’s a perfect match.
    The pen style is better than brush applicator, applies easily and blends good; see if you can get that style from dealership. Up here that’s the only style they sell. One end has a colour nib, the other is clear coat. Your mileage may vary, but I found the clear coat was lifting the colour coat, avoided using after the first disaster. Looks good without.
    #6 Mendel Leisk, Jan 1, 2021
  7. Ianmeister
    316
    320
    Meridian Idaho
    um, no the picture is of alloy mags.
  8. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    "um, no the picture is of alloy mags."
    They may or may not be alloy mags, but they are indeed the stock wheels; what you see when you take the (stupid, IMO) wheel covers off.
    Raytheeagle likes this.
  9. Tideland Prius
    16,681
    Yes. And we're telling you that they're stock alloys and that you're missing aerodynamic wheel covers that previous owner probably tossed out.
    Yes the Prius is weird that way - alloys AND wheel covers. No matter, at least you get two different wheel designs for the price of one :LOL:.
  10. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Yep. Like I said, those alloy mags are stock, beneath the plastic wheel covers.
  11. Ianmeister
    316
    320
    Meridian Idaho
    Ohh. That’s odd. Why would they put cheap plastic covers over mags. I don’t get it. Do the covers are tidally increase mileage?
  12. Mendel Leisk
    42,354
    That was my question in 2010 lol. Plus, since nobody’s ever going to remove the covers [:rolleyes:], the alloy rims are utilitarian looking.
    This in part steered us to a CDN Touring model, with nice looking 17” rims (without covers). There’s also a couple of nice-looking and bare 15” rims: the aforementioned PIP (Plug-In Prius) rims, and I believe one of the gen 4 Prius levels.
  13. Tideland Prius
    16,681
    They're for aerodynamic purposes (fill in the gaps between the spokes to reduce turbulence). It's also a weight and cost savings (since they could've used the same alloy to create the same design but instead went with an alloy design with less material then filled in the gaps with plastic).
    How much does it matter? I don't know if it's measurable without a spreadsheet.
    I usually keep mine off unless I go on the highway on a road trip, then I'll put it back on (I mean, that's what Toyota said it was for - aerodynamics).
  14. Rayman2010
    Rayman2010 Junior Member
    Millheim, Pa.
    I did a little black painting on my original plastic caps....look pretty cool 20210117_190637.jpeg 20201025_164734.jpeg
    Tideland Prius likes this.
