When checkingyour oil after the dealer changed it...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by NaptownPrius, Jul 16, 2008.
  1. dwreed3rd
    dwreed3rd New Member
    742
    Marietta, Ga
    But the question is this. Are the oil lines in/out, leading to the filter, above or below the oil level in the pan. I've always drained the oil pan before removing the oil filter. And made sure the new filter was on before refilling. This is the sequence in the owner's manual. But, as long as the point at which you attach the filter is above the level of the oil pan you should be O.K. If not, it could get messy.
  2. NaptownPrius
    NaptownPrius Getting Greener....
    271
    Napolis, Merlin
    The book says 3.9 quarts. I'd be surprised if you got that much out on a regular oil change. There are often tiny trapped pools of oil within an engine block or the lines.
  3. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    the oil pan is below the filter, so only what is in the filter will come out
  4. dwreed3rd
    742
    Marietta, Ga
    Got it! Should be O.K. then. Thanks
  5. bruceha_2000
    bruceha_2000 Senior Member
    3,057
    302
    Northwest VT
    2018 Prius Prime
    There isn't that much oil in the filter, it just happens to be messy when you start to take it off. It is at an angle and after you have turned it some, the oil starts to leak down the side. Several 'lessen the mess' options have been suggested:
    1. Loosen it a bit, but not to the point of leaking, put a ziplock bag over it and unscrew it (make sure the oil isn't too warm). The mess will end up mostly in the bag but you DO have a messy bag.
    2. Loosen it a bit, then punch a hole in the bottom of the filter with a nail. Drain the oil into a standard oil drain pan, then take the filter off. This one is still somewhat messy. If you drained the oil from the pan into this drain pan, no extra vessel for disposal.
    I wonder if there is a 'tap and drain' tool. Something that would work like when they puncture you to get blood: Tap it into the filter, attach a small hose, pull the 'plug' so you can drain it directly into a container. NO MESS!
  6. dumas
    dumas Junior Member
    44
    NC
    I played around with putting a cut-off 1-liter coke bottle over it as I unscrewed it, as some have suggested, but it was so awkward that now I just unscrew it very slowly until it starts to dribble out, then go do something else for 5 minutes while the oil that's going to leak out does, then come back and carefully unscrew it the rest of the way.
  7. richard schumacher
    7,683
    1,066
    United States
    NaptownPrius, did you wipe the dipstick dry before inserting it, and then pull it out for the read?
    Three quarts even is plenty for an oil change. It prevents overfills, and if you buy the oil, avoids having a leftover partial bottle. Try it and see.
  8. dwreed3rd
    742
    Marietta, Ga
    I like this approach! We just had the oil changed in the Avalon 5.0 quarts, @dealer, but took our own oil. Had picked up case on the way. One uopened quart left. Were does 3 quarts leave the oil on the dip stick? Still on wait list. Can't check t out.
    Thanks again! I like it.
  9. richard schumacher
    7,683
    1,066
    United States
    In seven out of seven oil changes in mine (I had not thought to try this on the first one, and by golly it was a bit overfilled) using three quarts leaves the oil level a little above the halfway point on the dipstick. In mine at least the level does not change noticeably during use.
  10. dwreed3rd
    742
    Marietta, Ga
    Sounds perfect.
    Thanks
  11. NaptownPrius
    271
    Napolis, Merlin
    Oh, yeah. I let the car sit for an hour and checked it several times. When the dipstick was pushed in all the way, it read 1/4" above the full dot.
    Now it is just below the full dot when pushed in all the way for a check.
    I will always check it before I leave the dealer from now on.
