When E power used up, engine makes noise when accelerating
Discussion in 'Prime Main Forum (2017-2022)' started by yunyi2009, Jun 15, 2023.
  1. yunyi2009
    yunyi2009 New Member
    Durham, NC
    and the noise is in direct proportion to how hard I push the accelerator. Is it normal?
    I bought this car over 2 years ago and it was like that from the beginning. I thought it was normal. And I brought my car back to the dealership for maintenance and there were no issues. I love this car and I suppose it was not a problem. Today, when I google it, it says something might be wrong with the alternator, etc. So I just come here and see if anyone knows better.
    Thanks in advance!
  2. Tideland Prius
    16,683
    Yes. It has a CVT and an engine that makes noise.
    There's no alternator in a Prius. The electric motors (MG1) help charge the 12V battery.
    Kris K. and Trollbait like this.
  3. yunyi2009
    Durham, NC
    So it's normal. Good to know. Thank you!
  4. PriusCamper
    PriusCamper Senior Member
    13,470
    5,438
    Pacific Northwest, USA
    Hybrid cars are a balance between electric and gas engine... The lower the charge you have remaining on your battery pack, the harder the engine has to work. Many make the mistake of trying to only use the electric part, which then over-uses the gas engine to recharge the battery. So the less you try to drive all electric, the less noisy the engine. Many just recommend driving it and not thinking about it because the car is designed to take care of itself. But if you're interested in max MPG do a google search on "pulse and glide" driving technique and then start practicing.
  5. Washingtonian
    Washingtonian Senior Member
    726
    621
    The OP has a Prime. I think most of what PriusCamper is saying does not apply to the Prime. Actually, the more I drive all electric the less noisy the engine as the engine is not being used. However, when the engine only is being used it is more noisy than the engine in a comparable ICE car. Not sure why that is.
  6. audiodave
    audiodave Active Member
    800
    272
    US
    Have you driven a regular gas powered car before?
  7. bisco
    52,878
    Yes, the engine noise is normal
    yunyi2009 likes this.
  8. CharlesH
    2,798
    1,166
    Roseville, CA
    "Pulse and glide" is a technique relevant for non-plugin hybrids, where all of the power ultimately comes from the gasoline engine. It is a technique to keep the gasoline engine running only at its most efficient RPM, or else be off. I guess it apply to the Prime if one is using it as non-plugin hybrid, when the traction battery is discharged.
  9. yunyi2009
    Durham, NC
    thanks!
  10. yunyi2009
    Durham, NC
    I can't post replies to some of the commenters. Not sure why. But thank you all for the input.
  11. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    My Prime has more intake noise than other cars I've had. Nothing wrong with that, just a bit different. Intake noise is the sound of the air pulled into the engine when the throttle is quite a bit open...lots of push on the gas pedal.
  12. bisco
    52,878
    how do you differentiate it from other sounds during hard acceleration?
  13. PT Guy
    1,085
    713
    It sounds different from exhaust or other noises, and is only present during hard acceleration or steep hills at speed. This sound is totally dependent on how much I mash the accelerator pedal while the engine is running which opens the throttle butterfly.
  14. Trollbait
    12,832
    Is this your first car with an Atkinsonized cycle engine?
    The intake valves are left open for a bit at the beginning of the compression stroke. So some of the air-fuel mix gets pushed back into the air intake manifold. This gives the efficiency benefits of a high compression engine without needing high octane fuel. It just trades of power output. You might be noticing that in the sound.
