When goes in to Accessory mode given a warning message
Discussion in 'Gen 3 Prius Main Forum' started by Mahagodage Amal, Dec 8, 2019.
  1. Mahagodage Amal
    Mahagodage Amal Junior Member
    srilanka
    When i switched to accessory mode in prius zvw30 ,it shows warning message with yellow triangle.
    After about 5seconds its go off.
    I translated the japanese text to english.
    始動時はプレーキを踏みながらパワースイッチを押して下さい
    When starting, press the power switch while stepping on the brake.
    52,889
    that means the battery is getting low. leave it in ready, and you'll be fine.
    Johnny Cakes likes this.
  3. Tideland Prius
    16,683
    That’s fine.
  4. Mahagodage Amal
    srilanka
    I changed the 12v battery before about 8 months ago.
    After a long trip also this warning message come in accessory mode.
    Fulel consumption reduce also 7-8 mpg after this message getting.
    Did i need a scan and changed the 12v battery?
  5. bisco
    52,889
    why are you using accessory mode, and for how long?
  6. Mahagodage Amal
    srilanka
    I am not using accessory mode always and warning is coming when switched to accessory mode instantly.
  7. bisco
    52,889
    it's probably just a reminder that acc mode can run down your 12v. japanese version is different than here, so i can't confirm it
  8. bisco
    52,889
    if you are concerned about the 12v, i would get a volt meter and test it
  9. ASRDogman
    ASRDogman Senior Member
    8,069
    4,092
    I believe it "thinks" you meant to START the vehicle, and is just letting you know you need
    to press the brake pedal for the car to start. Mine does that, because I don't press the pedal
    just before I press the button. Pressing the pedal, then start again, makes it "ready".
