When I pushed P the car went into N.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by KJBernard, Jun 26, 2013.
  1. KJBernard
    KJBernard New Member
    I have a 2011 Prius Three. Has this happened to anyone else?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    If you were going over 3-4 mph this is normal to prevent damage to the transaxle. If you were at a complete stop then I would take it to the dealer if you can repeat it.
  3. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Plus, you will hear an audible beep when you press "park" while in motion.
    52,814
    did your garage door open?
  5. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    Could you have accidentally bumped the shifter right around pushing the button? That's the sort of clumsy thing I might do. It could put you in neutral if you hit the shifter just after pushing P, if your foot was on the brake (I think).
  6. doc2mee
    doc2mee Junior Member
    It happened to me once, and I found out that I did not depress on the brake hard enough.
  7. bisco
    52,814
    one post willy.
    jdcollins5 likes this.
  8. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    The answers are already given above, but I will chime in just to support.
    If you press park and it goes to neutral, you were either going over the parking pawl speed limit (3-4mph) or the brake pedal was not depressed fully. Similar results will happen if you try to go into reverse while in motion.
