When should I clean the EGR valve?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MPGHokage, Nov 3, 2019.
  1. MPGHokage
    MPGHokage Junior Member
    Utah
    I drive a 2014 Prius with 70,000 Miles on it, and i'm curious at what mileage would it be best to clean the EGR valve?
    Thanks!
  2. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    The NutsAboutBolts videos include one about cleaning the EGR pipe. This is very easy to do. It’s the pipe between the EGR valve and the intake manifold.
    Try this procedure and take a look inside the pipe. Inspect the deposits — light gray, or black and sooty? If there are sooty black deposits or a lot of crud, it’s a good sign that you should clean the EGR cooler.
    The related procedure is to replace the PCV and possibly install an oil catch can. The OCC can prevent the EGR problem from getting worse. At 70,000 miles, you might only need to replace the PCV, install an OCC, and that’s it.
    mikey_t likes this.
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    I would clean it now, mine was clogged at 80k
    m.wynn, mikey_t and Mendel Leisk like this.
  4. Mendel Leisk
    41,909
    PCV valve is more'n likely fine, but it's cheap to replace, and right there if you have the intake manifold off. But yeah put an OCC on it ASAP (think I used my acronym limit for today...).
    FWIW, I cleaned my EGR at 70k km's, and the intake manifold (it has EGR passageways), don't regret it.
    Tim Jones likes this.
  5. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    I agree with the others that you should go ahead and take care of it now. The EGR circuit is the EGR cooler, valve, pipe, and intake manifold, make sure to clean all of those out. And if you've never done so, might be a good time to run Techron or BG 44K through a tank of gas to clean your fuel system and injectors.
    Mendel Leisk and bisco like this.
  6. Tim Jones
    Tim Jones Senior Member
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    Now........................................................................
