When should I replace the hybrid battery?
Discussion in 'Gen 2 Prius Main Forum' started by Dummy, Sep 7, 2024.
  1. Dummy
    Dummy Member
    121
    23
    Colorado
    I’ve got a 2005 with 250k miles still running the factory battery. It gets 42 mpg on the dash readout and I’ve read on here that it should be bumping 50. My math tells me that the extra 5 mpg won’t be enough to justify the cost. Today I started wondering if the slightly weak hybrid battery is putting more stress on the engine. What all should I consider when deciding to replace it or not?
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    Really, the only consideration I have is if (when) the battery starts "acting up".
    Dashboard warning lights, rapid increase & decrease on the battery gauge, big drop in mpg (by 10-15 MPG or more), engine "revving much higher".
    All of these are common symptoms when the hybrid battery is failing.
    Brian1954, dolj, Dummy and 1 other person like this.
  3. Dummy
    Dummy Member
    121
    23
    Colorado
    I’ve got none of those symptoms, just the slightly lower fuel economy. Occasionally I’ll have a tank that averages 39 mpg (about every 4th or 5th tank).
