When should I use EV mode?
Discussion in 'Prius v Fuel Economy' started by EkleKnarf, Apr 29, 2018.
  1. dyun1dyun1
    dyun1dyun1 Member
    61
    40
    Severn, MD and Boone NC
    2017 Prius v wagon
    My EV mode shuts down at 20mph? and hard acceleration.
    iPhone ?
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    It should do it as long as the engine is warm, the battery has sufficient charge, and you're not mashing too hard on the throttle. Been that way in every generation. It's one of the biggest factors in why the Prius gets better fuel economy in the city than on the highway.
    #22 jerrymildred, Apr 23, 2019
  3. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    ICE will tigger on hard acceleration from 0 mph, too. EV will operate up to 43 mph. Higher than that the ICE kicks in to keep MG rpm in survival range.
    jerrymildred likes this.
  4. dyun1dyun1
    dyun1dyun1 Member
    61
    40
    2017 Prius v wagon
    MY17 will definitely not go to 43mph. I don’t think it will make it to 20mph.
    And yes, hard acceleration will killing.
    iPhone ?
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    "if I am cruising at a steady speed" Yes, if you are not cruising, it will not be as frugal. It appears to me you are in the UK, perhaps Wales? I am in an extremely flat, warm part of the US. I can drive 156 miles and only gain 90 feet ( 250 km, 30 meters)
    It is easier to stay in EV operation if you never go uphill.
    At least some versions of the European v's got a smaller LiIon battery in the center console rather than the NiMH battery under the rear cargo area that we got in North America. In Japan "The Prius Alpha is available in a five-seat, two-row model and a seven-seat, three-row model, the latter’s third row enabled by a space-saving lithium-ion drive battery in the center console. The five-seat model uses a NiMH battery pack." It may be that you have a different battery than we are used to, as all North American v's are 5 seaters.
