When to Kick in ICE to Add Just a Few Miles Range
Discussion in 'Prime Fuel Economy & EV Range' started by mr88cet, Jul 16, 2017.
  1. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    So, is the belief that failing to warm up all the way after it starts causes permanent damage to the engine causing this sound forever after, or does it just make that noise if you start it up again shortly thereafter?
    iPhone ? Pro
    51,855
    just when you start it the next time. but no one has done a tear down to look for damage. it's unclear exactly what is happening inside the engine.
  3. mr88cet
    2,313
    1,335
    Austin, TX
    Does this apparent effect go away over time, and if so, then how much time? In other words, does it seem to happen only if you re-start the engine, say, 15 minutes later, or can it be observed days afterward?
    iPhone ? Pro
    51,855
    typically, someone has started their car, and moved it around on their property. maybe 30-60 seconds, then shut it down until going out the next day, and that's when it happens. but there have been many variations.
    there is a tsb for an updated manifold for the early gen 3's, but it hasn't proved very helpful.
    best remedy has been, 'don't do that!'
    mr88cet likes this.
  5. alexcue
    alexcue Active Member
    346
    311
    So Cal
    Has anyone observed this on a Prime or Gen 4 for that matter?
    NJ-PrimeAdvanced likes this.
  6. bisco
    51,855
    not that i recall.
  7. NJ-PrimeAdvanced
    204
    134
    New York/New Jersey
    Looks like Toyota addressed this issue? modern engines shouldn't really get into trouble, especially in a modern and tech-advanced car like the Prime... surely! :)
  8. mr88cet
    2,313
    1,335
    Austin, TX
    My guess would be that other factors were at play...
    iPhone ? Pro
  9. bisco
    51,855
    yes, design errors that probably required throwing the baby out with the bathwater.
  10. mr88cet
    2,313
    1,335
    Austin, TX
    Actually, now I'm thinking the best bet is to fire up HV mode right as you start up the car, on that won't-make-it leg of the journey (if you know ahead of time). Then, after the warm-up cycle, drive a little HV only during the faster parts of that leg of the drive.
    I suggest that because, if you take the warm-up-cycle hit, at a stand-still in Park, will charge the battery whereas, if the warm-up cycle hits while you're driving, it appears to keep driving on battery power until it completes. At least I presume it does, since that's what it did on our gen-2.
    So, you take the warm-up hit either way, but at least it charges the battery during the warm-up cycle rather than draining it!
    iPhone ? Pro
    #30 mr88cet, Jul 30, 2017
  11. mr88cet
    2,313
    1,335
    Austin, TX
    I had to burn a few tablespoons of gas just now, so I tried this. Kinda works, but not quite: Unlike our Gen-2, the P.Prime does not immediately run the warm-up cycle if you switch to HV mode at a standstill (and BTW I think my stepdaughter's Gen-4 regular Prius is the same).
    They seem to have carefully designed it to make sure that the fuel burned in the warm-up cycle is for-sure wasted! Well, I'm glad it's at least shorter than the Gen-2, in part because using the cat to warm up the engine.
    iPhone ? Pro
  12. mr88cet
    2,313
    1,335
    Austin, TX
    Actually, thinking back to it, the energy monitor, I believe, did show power going to the wheels during the warm-up cycle.
    iPhone ? Pro
  13. Oniki
    Oniki Active Member
    652
    499
    Colorado
    My answer to OP: never
  14. mr88cet
    2,313
    1,335
    Austin, TX
    So, if you run out of EV range, the engine will kick in (unless you're it of gas too! ). The question is how and when to kick it in for just a few miles somewhere on that leg of your journey, to burn the least amount of gas during the few minute/miles when it is on.
    iPhone ? Pro
  15. bisco
    51,855
    if i know where i am, i kick it on just before reaching my destination. the distance depends on the weather, speed and hills. that way, it's off when i reach my destination, and the warm up has added enough ev to get me there,
    if i don't know where i am, i kick it on a little sooner, so i know it will be off before arriving.
    if gen 4 doesn't mind partial warm up, i suspect letting it come on after ev depletion is most efficient.
  16. mr88cet
    2,313
    1,335
    Austin, TX
    On at least one occasion, I've seen it continue to run off battery power during the warm-up cycle, rather than the warm-up cycle adding power to the battery.
    Perhaps the trick is to, whenever you kick in the engine, and while it does the warm-up cycle, put it in charge mode...?
    iPhone ? Pro
  17. Krzysiek_KTA
    Krzysiek_KTA Active Member
    159
    125
    Houston
    That is exactly what I routinely do ( for other reasons though - see my other post).
    Nevertheless from what I observed on the energy flow display it takes a while after engaging CHG mode to see the arrow indicating that traction battery is charging.
    NJ-PrimeAdvanced and mr88cet like this.
  18. Oniki
    Oniki Active Member
    652
    499
    Colorado
    I understood your question. When EV ends, ICE begins. End of story
    I might feel differently in the winter cold but for now the ICE warm-up is fast and efficient.
    The problem with force charging is that you may be taking the Prime ICE out of its efficient ICE load to charge the battery. Left to it's own, the car is optimized to handle the warm-up. Without instrumentation you have little idea of how you are doing.
    The other problem is that you never know how many EV miles to reserve. Anything extra you arrive with was wasted; estimate too little and you go through the warm-up cycle twice.
    #38 Oniki, Aug 4, 2017
  19. Krzysiek_KTA
    159
    125
    Houston
    From what i observed engaging CHG does not affect the warm-up cycle. Regardless of D, B or CHG mode the war-up cycle is managed by the car. That is what I observed.
  20. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    After driving my commute in different sequences of EV/HV I've come to the same conclusion as Oniki. My only concern is the long term battery health because I must be draining the traction battery well into the HV reserve when I turn the car off still in ICE warm up state. I never experienced ICE shaking next day start up as Bisco described.
    Another benefit of running in EV till EV range is out is that I often find myself making it home in all EV by turning off AC and fan at the precise moment.
