When to Replace 12V Battery
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Siward, Sep 30, 2016.
Tags:
  1. Stephen Herman
    Stephen Herman Junior Member
    17
    North Carolina
    How does one know when the regular (non-traction) battery needs to be replaced. 2014 prius. What are the warning signs? When I press the start button all lights come as normal EXCEPT the green ready light. All other lights keep blinking showing they are working. After a few attempts then the Ready light comes up and car is operational. Does this simulate the grinding of a non-start button car indicating a worn out battery? What brand battery is recommended for replacement? Is walmart's everstart could enough? thx for any info.
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,354
    982
    Monument, Colorado USA
    You want to replace it now....at 10-years you've gotten about 3-4 years of extra life! Many reports of scary electrical issues show up when it's close to dying.
    I just replaced my wife's 12-volt in her 2017....it was testing at 70% with my tester. (You can get the same check free at any car parts store.)
    $208 at my dealer for a Toyota TrueStart with cca 470 with an 84-month warranty.
    Stephen Herman likes this.
  3. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    Is it the original 12v battery? If not, how old is it and what brand?
    Toyota makes the best battery for their car. And no "making it fit/work".
    I do recommend charging it for about 8 hours at 5 amps or less. They don't charge
    them at the dealerships or parts stores.
    chinarut and Stephen Herman like this.
  4. Stephen Herman
    17
    North Carolina
    same battery in car since purchase (18 months ago) happy to replace it. this car has been the best ever owned. totally trouble free, great gas mileage. this with 250k miles 31k of which i put on it. will go to dealership to tommorrow and replace it with new toyota one. appreciate your and coloradoboo's help.
    ColoradoBoo, bisco and ASRDogman like this.
  5. Canard
    Canard Member
    223
    Ontario, Canada
    Where's the best place to get a new battery in Canada?
    My dealership quoted $375 and won't tell me any info about what it is (say it's their "policy"). I found this one on Canadian Tire for $300 but not sure if they charge them first.
    General PDP Template | Canadian Tire
    I saw someone earlier in this thread mention this one, which is cheaper, has more CCA, but didn't come up as an option when I filtered for 2010 Toyota Prius:
    Neither NAPA or PartSource show anything for a Prius when I punch that in.
    (I got 7 years out of my first one and I'm at 7 years again, and am starting to get electrical gremlins and realize I should have replaced this a few years ago.)
  6. ColoradoBoo
    1,354
    982
    My dealership got so confused on just WHAT my 2017 needed that they just had me take a picture of the top of my battery so they could read the info from it! (I don't know why Toyota has to make this so complicated!)
    Canard likes this.
  7. ASRDogman
    8,067
    4,089
    It's not "Toyota", it's the "human". Sadly, they aren't beeing bread very well, nor are they
    being taught how to use their brain..... (y)
    I wouldn't be surprised even with a photo of the battery, they mess it up!:eek:
    ColoradoBoo likes this.
  8. ColoradoBoo
    1,354
    982
    You're right....I once asked for a simple clip that was missing from the trim in my Tundra and the part they brought out wasn't isn't close!! (I ended up finding something that fit from my big box so assorted clips.)
    ASRDogman likes this.
  9. ASRDogman
    8,067
    4,089
    I'm fortunate to have two dealerships that have a good parts department.
    One in Sarasota and one in Vero.
  10. Mendel Leisk
    42,354
    I'd have no qualms about going with that one. SaskBattery had Yuasa batteries, last time I checked, too. Might be a bit lower. Outside of Saskatchewan they were only charging GST, and shipping free.
    Higher CCA (Cold Cranking Amperage) is not necessarily advantageous, and it usually comes at the expense of Amp Hours, which is important as well.
    I doubt any retailer would do a charge on a battery they're going to sell you. A semi-fresh battery should be in decent shape, and just installing and driving should top it up. It is a good idea to do a full charge session though, with a decent smart charger, around 4 amp rating.
    I put the last battery in our '10 in September of 2015, still testing like new. It's a Optima Yellow Top (FWIW, has high CCA rating, but compromised AH). Our usage has dropped off, to where we're only useing the car once/twice a week, but good drives. In between use it's more-or-less constantly on a smart charger, with quick-connect cable connection, for convenience and secure connection.
    Next time around I'll probably go with Canadian Tire.
    #90 Mendel Leisk, Sep 23, 2024
    Canard likes this.
  11. Canard
    Canard Member
    223
    Ontario, Canada
  12. Mendel Leisk
    42,354
    Looks good, similar specs to Yuasa.
    See there's a PartsSource just up the road from us in Pit Meadows, food for thought.
    Options abound:
    PartSource:
    Canadian Tire:
    #92 Mendel Leisk, Sep 23, 2024
  13. ASRDogman
    8,067
    4,089
    Don't trust them! Put a 5 amp or less agm charger on the battery for
    at least 6 hours, 8-12 is better. Unless the charger tells you it's charged...
    Why risk it. It's best to start with a fully charged 12v battery..
  14. Canard
    Canard Member
    223
    Ontario, Canada
    Picked up and installed this battery yesterday:
    MPA-S46B24R Pro-Series XD Battery — Partsource - $304 CDN
    Easy job. Tip: On the Negative battery terminal there's a short wire that connects it to the frame. It was easier to remove it from the frame, swap the stub cable to the new battery, then re-attach it to the frame.
    Out of curiosity, what's the little sensor on top of the battery hold-down bracket for?
  15. Mendel Leisk
    42,354
    Good to know, another "reasonably" price option, at least in today's inflationary times.
    Did that hold-down bracket seat properly? When I put in an Optima Yellow Top, there was a mm or two height variation, and I needed to tuck shim washers in. The Toyota hold-down bracket is an absurd design.
    No clue about the sensor.
  16. Siward
    Siward Active Member
    314
    128
    Toronto
    Wow, battery prices are going up. I bought the same Eliminator battery from Canadian tire in Ontaro:
    1) July 2016 for $199.99 CAD (bought)
    2) July 2021 for $249.99 CAD (bought)
    3) Sept 2024 is now $300.99 CAD (just looked at price)
    chinarut and Mendel Leisk like this.
  17. Mendel Leisk
    42,354
    Last time I checked dealership it was over $400 CDN.
    johnHRP likes this.
  18. johnHRP
    johnHRP Active Member
    646
    191
    KA, DE
    Excel
    Battery price depends on the stock from Yuasa Japan, and local stores pricing. I saw it for €170 couple days ago in Autodoc
  19. johnHRP
    646
    191
    KA, DE
    Excel
    Just an update. Newer Toyota hybrid with 12V battery in the trunk is no longer AGM battery. I wonder if I should buy cheaper €52 compatible non AGM battery from VARTA, Bosch, or Exceed, A15 form factor. It fits like perfectly although a bit narrower than the original Yuasa hj-s34b20r 35Ah. They are also a bit more capacity 40Ah with a vent hole, just a bit shorter in dimension, 187/127/227 mm. It is for an Auris station wagon hybrid.
    5401270333132 | VARTA Automotive Batteries
    The battery is still original, made in December 2015. It is already 10y old, but never have any glitch. The voltage from the jumper is about 12.7V, in ACC mode, it drops to 11.9-12V, which does not change since 4 years ago. I never really load test it. But the voltage never drops below 10V whenever I start the car even with headlights and blower on.
    Yuasa battery is really good and durable, but many report that VARTA A15 battery also last 8y or more.
    #99 johnHRP, Jul 13, 2025
