When to Replace Engine and Inverter Coolant?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Den49, Jul 6, 2012.
  1. Mendel Leisk
    42,386
    It's weird, must be a different publication. The date says 1/10 which I gather to be Jan 2010 (yellow highlight):
    There's that footnote, which says to read the relevant Explanation of Maintenance Items, which turn says nothing about changing the dates/distances:
    I'll attach the whole thing.
  2. Virg
    Virg Junior Member
    28
    Austin Texas
    I just follow the expert's advise....the service manual recommendations.
  3. Den49
    Den49 Member
    498
    272
    Maryland
    Mendel - The document you attached is the revised "Prius 2010 Warranty & Maintenance Guide". Look at the bottom of page 51 where you will find footnote 3.
    #23 Den49, May 11, 2015
  4. Mendel Leisk
    42,386
    Yeah besides being out of date it's also out to lunch: practically every interval mentions engine/inverter coolant. And the footnote 3 on page 51 seems orphaned, nothing seems to ref to it. Guess that got fixed on newer version. I'm throwing in the towel.
  5. Mark8007
    Mark8007 Junior Member
    25
    Fort Wayne
    My 2010 Prius just turned 100,000 with no repairs yet. I will be changing the engine and the inverter coolant soon. I was also told to change the transaxle fluid too.
  6. Mendel Leisk
    42,386
    Oh, do the transaxle fluid asap. An early change, say after a year or two, 20~30k miles, is good. Then stretch the interval.
  7. gboss
    gboss Member
    173
    63
    Mountain Town in CA
    Why is the Toyota recommended change interval for the engine 120 months and the inverter coolant at 150 months? I thought the coolant turns acidic over time...why would the inverter turn less acidic than the engine coolant over time?
    I just finished my EGR circuit and was about to replace both engine and inverter coolant at 111,000 miles as it seemed logical to get both out of the way.
  8. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    In the inverter circuit, the coolant temperature is significantly lower (140 °F) 60 °C than in the engine circuit (203 °F) 95 °C
    johnHRP and gboss like this.
  9. rjparker
    rjparker Tu Humilde Sirviente
    11,152
    6,992
    Texas Hill Country
    Agree the inverter does not get as hot and is less likely to get contaminated. However the inverter will code at 149f and internal temps fluctuate quickly so effective coolant and water pumps are still essential.
    Why 100,000 on the engine coolant? Likely because the best premixed Toyota coolant is advertised as Super Long Life. If you use their only other option, Long Life concentrated coolant, it is half the miles. Possibly because Toyota does not trust people to mix properly with distilled water.
    #29 rjparker, Sep 3, 2024
    gboss likes this.
  10. gboss
    gboss Member
    173
    63
    Mountain Town in CA
    You guys bring up some good points - the coolant is also exposed to more continents in the engine circuit so I'm sure that adds to the breakdown. Interesting to hear about the Toyota Super Long Life coolant vs the Long Life.
    Here is what my engine coolant looked like at 111k (inverter coolant is still bright pink):
    like a bright orange sunset.
    johnHRP likes this.
  11. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    How hot does the engine get? 1000 degrees, or more?
    How hot does the inverter get? A few hundred?
    That's the difference.
  12. johnHRP
    johnHRP Active Member
    646
    191
    KA, DE
    Excel
    All chemical degradation accelerate with temp exponentially ~ Exp(const/T) in Kelvin. That's why the dye colors change in the engine is faster and probably other additives (sebacate, 2-EHA, etc.) degrade too.
    The phosphate main job is already done in the first few hours in the passivation of the metal surface and protect it from rusting.
    I remember that Ford newest coolant also contains phosphate now, not just organic acid.
